Just wondering where I can get my hand on a carburettor rebuild kit to suit a 1985 KLT250 prairie. Thanks.
Matt
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
All you should really need are the 2 big O-rings, (Fast idle cover and Bowl) Float Valve, and the small O-ring for the idle jet. Those are all available on Ebay.
Ok thanks. Might just get my dad to give it a proper clean out as its his bike. Will have a look on eBay for the seals. Thanks.
If you need part numbers or some direction let me know. If you take it apart real careful probably can reuse everything but the float valve and maybe that too!
Thanks mate. My dad ended up picking up another wreck and apparently it has a good carb on it, so we will start with that. Thanks for your help.
Matt
