Sorry all I can't seem to add a video. But cut to the chase here. 1985 200M high low chain driven. New parts: coil,cdi harness completely rebuilt, plug(also gapped) voltage regulator, carb,fuel line with inline filter, new tank petcock, head gasket, timed both valve and ignition, blah blah there's more sure. It starts right up, idles fine. You can rev it a little, any more then half and its right out but the rpm does not seem to climb much. Pulse generator is gapped BUT I'm sure this is the problem.. To me it sounds like isn't advancing properly. It moves freely but the problem is how can you tell if the springs don't have the proper rate? I can't find a new setup, and my other spare engine was doing the same thing. This is absolutely insane the hours I've put into this with the hardly helpful manual, but everything ohms out. I've eliminated fuel. Brand new carb. Please toss some ideas at me veterans!
