I just picked up a 1985 350x as a project. The clutch was shot when I bought it. So I replaced the steel plates and the fiber plates. When I start it it will shift into gear and if I pop the clutch the wheels will kick about an inch but no other movement. I have made sure all the parts are there and installed in the right places. The one thing I was unsure about is the plate that the plunger pushes on is inset in the clutch basket could this be what is causing the problem it is tightened to far in?
