Hello all - help needed.
In regards to my '84 Honda 200es - can someone explain the needle jet and what happens when repositioning the e-clip in one of the 5 notches.
Here is what is happening. A while back I took apart the carb for routine maintenance and clean it. Not sure if previous owner ever had it serviced. Big Red was running fairly well. I noticed that the e-clip was installed on the top notch on the needle jet. As per the owner's manual - I reinstalled it in the 3rd notch. Altitude here is 1,895 feet. Main jet is #95. Fuel mixture pilot screw is 2 turns open from a fully closed position. Running NGK DR8ES-L plugs. Plug gapped at 0.028". Now I am fouling plugs like crazy. New plug will last for one ride and the next day it will not start. If I put in a new plug it starts instantly. Is the float not at the right height??? Was the e-clip set at the top notch of the needle jet to compensate for something??? Comments/opinions greatly appreciated. Thank - you.
