Results 1 to 15 of 18
Thread: 200x Tripple Clamps and Forks on 84 250r
    Jan 2013
    Canada
    27
    I am starting to get back into fixing up my 84 250r. The next thing on my agenda is the front froks. The froks currently on the bike are shot. I bought all new seals but the forks have sand and water down in them (from the previous owner), also one of the air valves is craked off (which is discontinued according to my local dealer). I would rather buy a good used set and and use/rebuild them depending on the condition. I found a set of 200x forks (not sure what year, see picture) with the tripple clamp. Seeing they are different part numbers, I was wondering would there be any problem trying to fit my 250r front wheel and axle assembly on these forks?
    Dec 2012
    To my knowledge you can use 350x forks in your 250r. I have a friend who swapped out fork components in his 85' 350x for components from an 83'/84' 250r. It gave him an extra 2 inches of front end travel. I would bet that the air valves from a 350x would work with your 250r. A good way to verify is to download both serivce manuals and compare the front suspension.
    Surprise, AZ
    2,428
    The 350x fork are leading axle, the 250r forks are trailing axle, the 350x caps work but the valve stem is casted in.
    I would stick with the 250r forks.
    Post pictures of your forks and I can help you more.
    Sent from my SM-G386T1 using Tapatalk
    Surprise, AZ
    2,428
    Quote Originally Posted by Turbeau View Post
    Putting 250r parts in a 350x only gives you .70 inch of extra fork travel, not 2" unfortunately.
    Jan 2013
    Canada
    27
    Thanks for the replies. Unfortunately I am unable to get pictures of my forks for 2 weeks (working away). My current forks are in really bad shape (sand and water down in them from the previous owner) and the bottom allen bolt on one is stripped out (chances are its discontinued too). I would like to try to get a decent used pair of forks. They don't have to be perfect or made for racing or jumping. There are no forks from an 83/84 locally or on ebay. There seems to be alot for the 200x. Would these forks fit my current triple clamps? or will I have to get a 200x triple clamp too? (then would the 200x triple clamp work with the 250r front axle and wheel?)
    Apr 2002
    s.w. michigan
    6,498
    I am 99.9 % sure 83/84 250R and 83/84/85 200x front ends are identical excepting for rim color.
    john
    Jan 2013
    Canada
    27
    Thanks! That should mean the shock tubes are the same diameter? Hence no need to buy another triple clamp?
    Toaster556's Avatar
    Toaster556 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    Fraiser Valley, BC, Canada
    176
    I have an extra 35mm Honda fork cap if you want it, and I THINK I have a good condition allen bolt for the bottom too. Both parts are available according to my local dealer, maybe yours is just lazy. OTOH, if you go with different forks, I'd be interested in your 250R forks. Wherebouts are you in this currently fiery land?
    200X forks are 2mm smaller than your 250R forks and shorter travel (7.3 for the 200X vs 8.7 for the 83-84R), so I'm not sure they'd balance out. You may be able to put 85-86R forks on your trike, I'm pretty sure I've seen it done before.
    Jan 2013
    Canada
    27
    I am located in St. John's Newfoundland. Anything 250r related here is very hard to come by. If I could get those 2 parts in good shape and get the stripped bolt out I could fix them up with lots of elbow grease. If anyone has any idea if the 85-86 250r fork tubes would fit the 84's triple clamp please chime in.
    Surprise, AZ
    2,428
    83'84 250r are 35mm
    All 200x forks are 33mm
    Toaster556 is correct the bolts are available at partzilla.com
    Surprise, AZ
    2,428
    If your your upper fork tubes are good, I have a good set of lower sliders, and fork caps
    Toaster556's Avatar
    Dec 2010
    176
    Fork sizes:
    83-87 ATC200X 33mm
    83-84 ATC250R, 85-86 ATC350X 35mm
    85-86 ATC250R 39mm
    85 Yamaha Tri-Z 250 35mm
    86 Yamaha Tri-Z 250 39mm
    I have those two parts in very usable shape if you want them
    Jan 2013
    Canada
    27
    I might just go the rebuild route. Would you happen to know the diameter of the 1985-86 250r forks?
    Surprise, AZ
    2,428
    39mm, 9.8 inches of travel
    Dec 2010
    Back in VA baby!!
    711
    The first gen 200x forks are actually lighter than your fooler forks, but at the cost of less travel...the good news is that the front brake set-ups are identical and would swap over. You can keep your fooler triple trees if you buy adapters to fit the smaller diameter 200x tubes, but I haven't seen those around in a while. If not, you shouldn't have too much trouble finding the proper forks for your R, seems not too many people ride the air-cooled Rs anymore..
    S3 repros
    Trikefest '12 '13
    86 350x
    87 250sx
    84 70
    78 90
    Reproducing hard to find parts...check out the store
