AS the 250R restoration project is nearing its end, I decided to add brake fluid and bleep the brakes. The rear went fine. The front I worked on for over an hour and it is still spongy. I even used a pnematic bleeder, but same thing. I thought that because the hose was higher than the master cylinder that it was holding air at that point so I lowered the hose and still have the same issue. I did notice that when I squeeze the brake, there is alot of flexing in the hose. The hose I am using was a reproduced one from ebay. I am wondering if anyone else has used this hose and if they have had any problems. I am thinking that the repo hose is a thinner hose and therefore expanding when I squeeze the lever. Any input? Here is a link to the hose I am talking about.
http://www.ebay.com/itm/HONDA-ATC-25...-/221764087891
