Results 1 to 8 of 8
Thread: about my tri-z2500 and wot engines will fit straight in it ?
    bil is offline New to the board Arm chair racerNew to the board
    Jul 2015
    UK Southampton weston
    16
    Hi I have a tri-z 250 it is in complete bits I can't wait to get it done I was wondering if there is a better engine to put in in is the yz engines better and wot engines will just fit in the tri-z thanks bill
    Jan 2014
    Massachusetts USA
    782
    Hi Bill! The Tri-Z shares the same bottom engine mounting locations with 82-87 YZ250, '81 IT250 and maybe later years but definitely not earlier, and all the variations of IT/YZ 465 and 490. But just because it bolts in doesn't mean the carb and exhaust will point in the same angles. Intake and exhaust angles varied model to model and from year to year in some cases.
    1985 Tri-Z 250
    1985 ATC250R
    Jul 2015
    16
    Thanks for the reply m8....is the tri-z engine any good is it got as much power as the yz 250s if the yz are a lot better I will definitely modifi it to fit a yz Engine so if so if I have got to modify it any out of the engines u said wot one would be the best to put in it and do u no out of the engines would be easiest to fit thanks drew
    Jul 2015
    16
    Sorry mate I just realize the 82 yz 250 and 490 was air cooled so if 87 yz is a lot better than the tri-z I will put the 87 in I think u can bore the 250 87 to 300cc do u no anyone who has put the 87 init is it hard work will I have to cut the frame thanks drew
    Jan 2014
    Massachusetts USA
    782
    Only the IT250 and the 465/490 engines are air cooled, 82+ yz250's are water cooled. YZ250 engines have the centered exhaust so its easier to bolt in than the others. 83-87 engines are very similar to the Tri-Z engine, same 68x68 bore and stroke, but they have a power valve the Tri-Z doesn't. Also they are ported more aggressively. 82 has 70mm bore, 64 stroke, different shaped head, but otherwise just like the 83-87. Also, the left side of the crank is different from Tri-Z to YZ, so YZ engines must run YZ ignitions, which have a lighter rotor and no output for headlights. Lastly, you can swap a power-valved YZ top end onto a Tri-Z bottom end, do a search, it has been covered here before.
    What is "best" is a matter of opinion, but at least you can make a slightly more informed decision.
    1985 Tri-Z 250
    1985 ATC250R
    Jul 2015
    16
    Lol I am thinking of rd 350 now lol someone said they think the banchee frame is the same as tri-z ? Do any no if that is true ???? Thanks
    Surprise, AZ
    2,428
    Most RD350s are air cooled, some were watercoled, the RZ350 is watercooled.
    The TRI-Z and Banshee frame is not the same or even close.
    If I was you, stick with the stock engine and add some mods if you want a bit more performance.
    Sent from my SM-G386T1 using Tapatalk
    Jul 2015
    16
    Is the rd 350 the same as the banchee engine and has anyone ever put rd or banchee engine in a tir-z????? Thanks
