Results 1 to 8 of 8
Thread: Atc 110 no start ..stumped
    Jun 2015
    Langford
    13
    Got spark, got fuel.. Good compression.
    When I pull cord it turns but nothing, also headlight comes on when pull cord.
    Clean carb. Ideas? Anything. Thanks! Click image for larger version.
    Sent from my iPad using Tapatalk
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    429
    If it's getting fuel AND spark it would start.
    You are getting a strong blue spark? How do you know it is getting fuel to the cylinder? Is the pilot jet clear of obstruction? Have you played with the idle screw?
    Jun 2015
    Langford
    13
    Got strong spark. Jets are clear as I cleaned the whole carb.
    NEPA
    7,051
    Adjust your valves. Otherwise, one of the 3 isn't there.
    6,813
    The very first thing I do when a non running machine comes threw my shop is a compression check !
    Jun 2015
    Langford
    13
    What's the second.
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    Is it in time??
    6,813
    Second is check for spark , and third is fuel , if it still doesn't start check valve timing .
    Quote Originally Posted by Morin139 View Post
    What's the second.
