Banchee 350 is it the same and has anyone put one of them engines in a tri-z ??? Thanks
The Banche is water cooled, the RD is air cooled.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
Is it the rd z 350 which is water cool is that one the same 2 cylinder one is that the same just wonderd cus I am getting one to put in to put in my tri-z I want to no cus I want the banchee engine cus I no the are rapid and can't find them when I search under banchee engine an just wondered if anyone has put bancheers engine in a tri-z ??? Thanks
Billy uploaded some pics of Trikefest '15, and there's a pic of an orange and blue Tri-Z with a Banshee engine in it. I'm not sure whose machine it is, or what it took to fit that engine in there.
1985 Tri-Z 250
1985 ATC250R
I believe aside from being air cooled the gearing was different in the bike. Higher top speed I'm assuming but with less bite. Use the banshee motor. Parts are more plentiful and a lot of aftermarket stuff too.
'' Mixin gas N haulin _ss''
1985 250R-310
1985 Tri-Z
1985 Tri Zinger-X's 4
1973 atc70
Up to 1980 the RD 350 & 400 was air cooled. The RD 350 of 1981 & 82 was water cooled and as far as I know the platform of the Banshee engine. The RZ 350 of 1983 and on were only called that in Canada and the USA. They continued to be called RD's in Europe. The main difference between the 81/82 and the newer ones is that they had the YVPS valves added. Look in the Showcase builds for "TriShee" and you will find one in part of a Tri-Z frame. You can also see it running in the more recent Trikefest drag videos on YouTube.
Photo credit to mr. Golightly.
There was another person here that did it too I'm pretty sure.
I was unaware that the water cooled version of the RD was even available in the U.S.
But then again I do live in California where 2 stroke street bikes were not sold here at that time.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
RZR XP 900
I want the same size wheels and tyres that r in the picture and the same long axall wot size is it all thanks bil and do any one no wot site I can get it all fromantic thanks
Back wheels thanks
18x10x10 titan fast trekkers...good luck finding them, that style was about last made in late 90's...they changed the treat pattern now.... 10in rear rims have no place on the back of an atv. you will bend them rims asap.
http://www.ebay.com/itm/Titan-Fast-T...88f213&vxp=mtr
Thanks for all information I am putting it on the road the wider and lower profile the better i need decent tyres and rimes if anyone no a place I can get some from please let me no thanks bill
Does anyone no where I can get triple trees from for my tri-z so I can put upside down front forks on thanks
www.HREatv.com will build you them. We build a set of them for my YZ85 forks for a 200x. He will be cheaper then HALLs performance kit's if you have time to kill. Personally having owned inverts I see them as over kill unless your gonna race MX and get big air. If your gonna do all that work you need to gusset up that frame. I find if you just get your stock suspension redone that will work just fine with stiffer springs or different oil weights.
Here were the ones he build for me. I end up selling them to a guy who bought some atc parts off me few weeks ago.
