Results 1 to 15 of 19
Thread: abouts rd and banchee engine r theye the same
    bil is offline New to the board Arm chair racerNew to the board
    Jul 2015
    UK Southampton weston
    16
    Banchee 350 is it the same and has anyone put one of them engines in a tri-z ??? Thanks
    devore,ca
    1,046
    The Banche is water cooled, the RD is air cooled.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jul 2015
    16
    Is it the rd z 350 which is water cool is that one the same 2 cylinder one is that the same just wonderd cus I am getting one to put in to put in my tri-z I want to no cus I want the banchee engine cus I no the are rapid and can't find them when I search under banchee engine an just wondered if anyone has put bancheers engine in a tri-z ??? Thanks
    Jan 2014
    Massachusetts USA
    782
    Billy uploaded some pics of Trikefest '15, and there's a pic of an orange and blue Tri-Z with a Banshee engine in it. I'm not sure whose machine it is, or what it took to fit that engine in there.
    1985 Tri-Z 250
    1985 ATC250R
    Jun 2014
    Pittsburgh
    107
    I believe aside from being air cooled the gearing was different in the bike. Higher top speed I'm assuming but with less bite. Use the banshee motor. Parts are more plentiful and a lot of aftermarket stuff too.
    '' Mixin gas N haulin _ss''
    1985 250R-310
    1985 Tri-Z
    1985 Tri Zinger-X's 4
    1973 atc70
    9,020
    Up to 1980 the RD 350 & 400 was air cooled. The RD 350 of 1981 & 82 was water cooled and as far as I know the platform of the Banshee engine. The RZ 350 of 1983 and on were only called that in Canada and the USA. They continued to be called RD's in Europe. The main difference between the 81/82 and the newer ones is that they had the YVPS valves added. Look in the Showcase builds for "TriShee" and you will find one in part of a Tri-Z frame. You can also see it running in the more recent Trikefest drag videos on YouTube.
    Mar 2013
    Central PA
    2,362
    Photo credit to mr. Golightly.
    There was another person here that did it too I'm pretty sure.
    devore,ca
    1,046
    I was unaware that the water cooled version of the RD was even available in the U.S.
    But then again I do live in California where 2 stroke street bikes were not sold here at that time.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Jul 2015
    16
    can someone help me in this picture I want the same wheels and tyres
ID:	218847 can someone help me I want to get the wClick image for larger version.
ID:	218847[ATTACH=CONFIG]218847[/ATTACHClick image for larger version.
ID:	218847Click image for larger version.
    Jul 2015
    16
    I want the same size wheels and tyres that r in the picture and the same long axall wot size is it all thanks bil and do any one no wot site I can get it all fromantic thanks
    Jul 2015
    16
    Back wheels thanks
    Willamstown PA
    5,824
    18x10x10 titan fast trekkers...good luck finding them, that style was about last made in late 90's...they changed the treat pattern now.... 10in rear rims have no place on the back of an atv. you will bend them rims asap.
    http://www.ebay.com/itm/Titan-Fast-T...88f213&vxp=mtr
    Jul 2015
    16
    Thanks for all information I am putting it on the road the wider and lower profile the better i need decent tyres and rimes if anyone no a place I can get some from please let me no thanks bill
    Jul 2015
    16
    Does anyone no where I can get triple trees from for my tri-z so I can put upside down front forks on thanks
    Willamstown PA
    5,824
    www.HREatv.com will build you them. We build a set of them for my YZ85 forks for a 200x. He will be cheaper then HALLs performance kit's if you have time to kill. Personally having owned inverts I see them as over kill unless your gonna race MX and get big air. If your gonna do all that work you need to gusset up that frame. I find if you just get your stock suspension redone that will work just fine with stiffer springs or different oil weights.
    Here were the ones he build for me. I end up selling them to a guy who bought some atc parts off me few weeks ago.
