Results 1 to 15 of 28
Thread: The Moto-Gote 2x2
    Jul 2015
    North Alabama
    12
    The Moto-Gote 2x2
    Hi everyone, newb here.
    I have been working on a 2wd trail bike project using a 1984 atc 125m, I call it the Moto-Gote. I have used info from this site a lot in researching this project, so I figured I should register and post it up for yall.
    Donor
    Parts pile
    I widened and recentered the 9" wheels
    Frame tacked together
    Sep 2014
    San Diego
    24
    This looks awesome. I'm excited to see how this turns out
    kaymo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2013
    Hickory NC
    191
    OMB member haha
    Maine
    4
    This looks like it will be a sweet rig! How do you plan on driving the front tire? Along the same lines as a rokon set up or something else?
    Feb 2013
    Hickory NC
    191
    might want to ditch those manco style cable brake calipers for some hydro units. I need a couple for some of my karts (only bc thats what they came with and i dont feel like converting) but I probably have a couple hydro units i could swap you for.
    Cold Lake, Alberta, Canada
    3,019
    You've got my interest, keep us posted. Should look awesome but handle like crap, lol. I've never rode a Rokon but having a wheel pull you would be a weird feeling. Having a fat wheel doing the same will be even more pronounced. Loving it! Where'd you get those mechanical disc brakes?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Feb 2013
    Hickory NC
    191
    the mechanical disc brakes are manco units. they might be ok for this but they are crap on karts!
    Jul 2015
    North Alabama
    12
    Hey guys, sorry I haven't posted up progress pics, been too dang busy to get much accomplished.
    The front wheel will be driven by a horizontal jackshaft through the center of the fork pivot with a u-joint for steering, then a chain down to the front wheel. Nothing like a Rokon, more similar to Arctic Cat Cub or Trail Partner bikes.
    I chose mechanical brake calipers and very small(6") rotors over hydraulic because I am worried about them being too sensative/touchy. They will be mounted "inboard" on the front and rear jackshafts, which means there is a 4.3:1 reduction (10 tooth sprocket to 43 tooth sprocket). So the brake rotors will spin 4.3 revolutions for each tire revolution giving a massive mechanical advantage to the brakes. Not to mention, this thing will be routinely buried to the handlebars in mud, so simple is good. Hell, I'm putting a snorkle and winch on it.
    The front drive shouldn't affect the handling at all until there is rear wheel slippage, then the overrunning clutch will kick in and send power to the front wheel. As long as the front tire is spinning the same speed or faster than the rear, the 2x2 system should be "transparent".
    3,019
    Sounds like this isn't your first rodeo. Keep the pictures coming!
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Jul 2015
    North Alabama
    12
    The brake calipers/rotors are Airheart brand. I ordered them on Amazon (pretty expensive for what you get).
    Jul 2015
    North Alabama
    12
    Some progress on the drivetrain.
    Here the overrunning clutch can be seen towards the right side of the rear jackshaft.
    3,019
    You sure have vision! I'm really interested where this is going. Keep the pics coming.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Jul 2015
    North Alabama
    12
    Fully welded ready for primer. You can really see how it works here.
    Jul 2015
    North Alabama
    12
    IT'S ALIVE! She is running, but nowhere near finished.
    Here are a couple videos of literally the very first ride. Not bad for someone who has never ridden a motorcycle, ha.
    https://m.youtube.com/watch?v=4Nih34qn6pg
    https://m.youtube.com/watch?v=pwsd3syzNsc
    Dec 2015
    East Kingston, NH
    91
    Interesting build!!! Lots of ingenuity in that one....I know the neat trick for the Rokon guys is to put a ATC125/110 engine in them, They're great with the high low range and maintenance free motors.
    '85 ATC350X
    '85 ATC110
    '85 ATC200X (gone)
    '84 ATC125m (gone)
    '86 Tecate 250 (gone)
