Results 1 to 15 of 16
Thread: Witch is better 250r or350x??
    Jun 2015
    harmony mn
    Hi i am looking into buyin a bigger race trike and i am not sure if i should get a 350x or a 250r does anyone have some specs on these trikes or an opinion for me thanx
    Jun 2009
    Leander TX
    2,217
    Depends so get one of each!
    Jul 2012
    Joplin, MO
    597
    ^^So your buddy has one to ride when his breaks.
    For a race bike. 250r
    Sent from my XT1093 using Tapatalk
    Jun 2009
    Leander TX
    2,217
    I then he breaks the 350X too
    At least both were easy fixes this time!
    I will say I prefer the R in the dunes - love the 2 stroke hit.
    Dec 2013
    250r is faster , but 350x is great for trailer riding. The 250r has a better suspension and the frame is much more durable. Take your pick.
    Feb 2015
    Tucson, AZ
    8
    Speaking of suspension, is that something I could upgrade? I just acquired an 86 350x and will begin restoration in the next month or 2
    Surprise, AZ
    2,428
    More info, what kind of riding are you doing?
    Sep 2014
    San Diego
    24
    The really can't imagine any time I would pick a 350x over a 250r. The 350x is heavier and sluggish in comparison. Especially for racing though, I'd go with the 250r.
    Jun 2009
    Leander TX
    2,217
    I must be getting old because there are times when I prefer the X - mostly when I'm tired because it doesn't demand as much from me.
    Aug 2014
    South Louisiana
    1,915
    Get which ever is easiest to find. Then look for the other one...
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Manheim, PA
    5,817
    350x is far from a race trike...needs a good bit or mods to be comes one. 250R would be better in stockish trim then slapping a set of 18's on it. 200x's make better MX bikes over the 350X i think, just so much lighter but need major help in power department.
    Blossvale NY
    4,563
    Need to know your intended use before anyone can begin to make a rational recommendation...
    There are times where the 350x is preferable over the R, and vice versa. Which one is better is completely situational. It all depends on the type of riding you are looking to do.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Sep 2014
    San Diego
    24
    In his original post he states he is looking for a bigger race trike. Sorry, my earlier post definitely made it sound like I wouldn't pick a 350x in any situation, but I was referring to different racing situations.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by jethro holdeman View Post
    Hi i am looking into buyin a bigger race trike and i am not sure if i should get a 350x or a 250r...
    You can race the 250 in the open class, but you can not race anything bigger than a 250 in the 250 class.
    The 250 takes fewer mods to turn it into a high performance bike.
    The 250 is a much lighter bike.
    Jan 2013
    minnesota
    5,911
    Hi i am looking into buyin a bigger race trike and i am not sure if i should get a 350x or a 250r does anyone have some specs on these trikes...
    Here's a link to the factory service manuals . . All the specs are on the first few pages.
    http://www.oscarmayer.net/atc/manuals/
    1985 thru 1986 ATC250R
    Engine type : 2 Stroke, Liquid Cooled
    Displacement : 246 cc
    Bore x Stroke : 66.0 x 72.0 mm
    Compression ratio : 8.0 to 1
    Compression : 142 - 170 psi
    Transmission : 6 speed
    1st - 2.570
    2nd - 2.062
    3rd - 1.667
    4th - 1.333
    5th - 1.083
    6th - 0.884
    Clutch Type : Manual
    Oil Capacity : n/a
    Carburetion : 85' 32mm Keihin, 86' 35mm Keihin
    Starting system : forward kick
    Fuel capacity : n/a
    Wheelbase : 51.0 in
    Overall Length : 74.6 in
    Overall Width : n/a, adjustable
    Ground Clearance : n/a
    Seat Height : 29.9 in
    Front Tires : 23.5 x 8 x 11
    Rear Tires : 20 x 11 x 9
    Front Suspension : Hydraulic telescoping forks with 9.84" of travel
    Rear Suspension : "Pro-Link" + Mono shock with 9.84" of travel
    Front Brake : Hydraulic Disk
    Rear Brake : Hydraulic Disk
    Final Drive : chain
    Dry Weight : 293 lbs
    MSRP : $2,298.00
    1985 thru 1986 ATC350X
    Maximum torque output: 21.7ft.lb @ 6000RPMs
    Maximum power output: 27PS (~26.4hp) @ 7000RPMs
    Starter type: forward kick
    Wheelbase: 50.0"
    Ground clearance: 4.7"
    Maximum load capacity: 270lbs
    Overall height: 42.6"(1985), 42.3"(1986)
    Overall length: 74.4"
    Overall width: 43.9"
    Seat height: 29.5"
    Foot peg height: 11.4"
    Fuel capacity: 2.65gal
    Engine weight: 91.5lbs
    Engine type: single cylinder, four-valve head, single over head cam, four stroke
    Fuel: unleaded
    Displacement: 350.4cc
    Bore: 81mm
    Stroke: 68mm
    Mechanical compression ratio: 8.5: 1
    Corrected compression ratio: n/a
    Cold cranking pressure: 178psi
    Carburetor type: dual valve
    Lubrication type: forced pressure and wet sump
    Ignition type: CDI
    Ignition timing advance: 10 degrees
    Electrical system:
    Dry weight: 320lbs
    Final drive type: chain
    Transmission type: 6-speed, no reverse
    Clutch: manual
    Transmission primary ratio: 2.833: 1
    Transmission 1st gear ratio: 2.750: 1
    Transmission 2nd gear ratio: 2.050: 1
    Transmission 3rd gear ratio: 1.609: 1
    Transmission 4th gear ratio: 1.308: 1
    Transmission 5th gear ratio: 1.103: 1
    Transmission 6th gear ratio: 0.935: 1
    Transmission final ratio: 3.077: 1
    Front brake type: disk, twin piston
    Front brake quantity: 1
    Rear brake type: disk, single piston
    Rear brake quantity: 1
    Camber: 0°
    Caster: 23°
    Toe in: n/a
    Trail: 1.36"
    Rake: 23-degrees
    Front suspension travel: 8.0"
    Front shock leverage ratio: 1:1
    Front shock type: telescopic fork
    Front tire size: 23.5x8-11
    Front wheel type: aluminum
    Rear suspension travel: 7.6"
    Rear shock type: gas charged (nitrogen)
    Rear tire size: 22.0x10-9
    Rear wheel type: aluminum
    Original MSRP: $2599
