Results 1 to 10 of 10
Thread: Help no start. Video included
    Jun 2015
    Langford
    13
    https://vimeo.com/134780100
    Slidell, LA
    4,738
    Have you checked spark, air and fuel?
    Jun 2015
    Langford
    13
    Got spark. Got air (pretty sure) and I got fuel as when I unscrew the carb drain screw fuel leaks out.
    Slidell, LA
    4,738
    What does the plug look like? When I heard it run in your vid it didn't sound like it had much for spark. Is it a fat blue spark?
    Jun 2015
    Langford
    13
    Yeah it's a decent spark. How do you hear spark...?
    Sent from my iPad using Tapatalk
    Slidell, LA
    4,738
    Are you being serious? What I am saying is it doesn't run for shite and it doesn't sound like the spark plug is igniting the fuel. Good luck bud
    Aug 2015
    Illinois
    To be completely honest with you, the motor sounds great but check your spark plug, if it's fouled or just wore out, that could be why it's not starting. If the spark plug isn't the issue, I'd look at maybe a clogged carb. But other than that, it sounds fine to me. :-)
    NEPA
    7,051
    I Nominate this post of the year
    Sep 2005
    MICHIGAN
    2,027
    Have removed spark plug, sprayed starter fluid in the plug hole, replaced spark plug, and then tried to start it?
    86 T3
    84 T3
    86 KX250
    glendive, montana
    1,822
    ok from what I can see of the plastics and motor I am going to assume that is a 185 or 200. now at the top of the motor there is a cover that says cdi on it, it is not the cdi but the pulse generator behind the cover. If that is turned 180 deg you will have spark but at the wrong time take it out and flip it so that the metal contacts you see are at the opposit direction, and try it again if that doesn't work put it back the way it was and check your compression. If you are not understanding what I am saying check out a manual on this site and it will show pics for you.http://www.oscarmayer.net/atc/manuals/
