Results 1 to 11 of 11
Thread: 82 250r axle question
    Oct 2014
    tn
    110
    Hey all I just got what I was told was an extended 200x axle. After some googling I found out it's an 82r axle. My question is how long are the stock axles end to end, this one measured out at 39.5 I ask so that I know what I have here thanks,
    Oct 2014
    tn
    110
    Just got a pic to upload
    Sent from my LGL34C using Tapatalk
    6,811
    Looks like a +6" 200x axle to me . It will work on an 82r if you use the 200x sprocket set up .
    Oct 2014
    tn
    110
    Thanks short line. Based on measurements I provided durablue yesterday I believe it's one of there's
    6,811
    If it requires hub spacers then yes durablue . Could also be a finishline , maxtrax or NASA
    Oct 2014
    tn
    110
    Went out to check it and it doesn't require spacers. Again.thanks for the help
    Oct 2014
    tn
    110
    Was finally able.to load these close up pics of the axle. Dang phone takes forever
ID:	219296   Click image for larger version.
ID:	219295   Click image for larger version.
    Carthage NY 250r rules
    2,355
    It looks like a NASA. I have both a Durablue and NASA for an 82 250 r plus a NASA for my 81 250 r. And your axle looks like my NASA . Do you have the hub nuts.
    250r rules
    Oct 2014
    tn
    110
    No how it's in pics is how I got it.
    Oct 2014
    tn
    110
    [QUOTE=flynfish;1378892]No how it's in pics is how I got it. Have extra 200x sprocket hub and axle nuts and they slid on with no slip or slop.
    Oct 2014
    tn
    110
    Atc300r. I would appreciate any other information you could give on this axle. Tried googling them and nothing. Thanks
