Picked up a rough 81 250r this morning. 3-4 years ago had top end rebuild, <10 hours run time, then sat in the shed. Good compression, tranny went through all the gears. Shocks are all good. Intake boot is shot, choke on carb is busted and held on with wire. Reeds and cage look good. I want to build a solid ridder with some extra "go" to it over stock. It doesn't need to handle massive jumps or be the ultimate racer. Just a fun ridder to take on some dunes, trail riding, and snow. Yes I know it won't touch a liquid 250r, I don't have the money for one of those.
This will be my first 2 stroke trike so I welcome any and all advice. I have old lawn boy 2 strokes, chainsaws, and trimmers so I'm not completely 2 stroke illiterate, however 250r specific advice is what I'm after.
For my build here is what I'm thinking for bolt on go fast parts:
85 250r keihin PE 34mm carb or something similar.
Fl350 odyssey intake boot.
Uni filter with outerwear, ditch stock airbox, build a free flowing replacement unit.
Probably a DG pipe. Won't be able to afford a vintage good one I'm sure.
200x front end swap.
Trx 300,400,450 rear hubs.
If any of this sounds wrong or there are better options, please share.
Of course some pictures!
Thanks for the help!
the turns really hard. Enjoy your first smoker, you'll be hooked. Keep your eyes open for a vintage pipe, I got my bassani from a member for $45, just needed paint.
s can go. They're so de-tuned from the factory and really take to mods well.
