Results 1 to 13 of 13
Thread: 86 200x swing arm bolt
    Feb 2015
    Bismarck, ND
    49
    Does anyone know if the 86 Swing arm bolt (90117-HB5-006) is the same as any other model that is still available from Honda? It was only used on the 86/87, but any slight change would warrant a new part number. Any help is appreciated.
    Aug 2014
    South Louisiana
    1,915
    86-88 trx200sx is a direct swap. Only difference is the 200x bolt is hollow.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Feb 2015
    Bismarck, ND
    49
    Quote Originally Posted by Jmoozy27 View Post
    Thanks for that info. Ill keep that in mind. I think I am going to have one made. Does anyone have a picture of the head of the bolt that they can send my way? I want to at least make it look it OEM if I am having one made.
    Mar 2007
    Texas
    5,045
    Better option is to have the 250R bolt trimmed and retreaded to the size you need.
    86-89 trx250r/atc250r same bolt.
    ________________
    https://www.mikesatvfix.com
    Surprise, AZ
    2,428
    Post the measurements
    Sent from my SM-G386T1 using Tapatalk
    Aug 2014
    South Louisiana
    1,915
    Hope this helps...
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Feb 2015
    Bismarck, ND
    49
    Hope this helps...
    It does. Thanks!
    Aug 2007
    Montana
    857
    When I get in trouble and can't find the correct bolt .....! I go get a fron't axle bolt from the Big red and re make it!!!!! Simlpe !!!!1
    DO the Best With What you got !
    My Feed back :cool
    Aug 2014
    South Louisiana
    1,915
    I have found many ways to solve 3 wheeler problems...
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Surprise, AZ
    2,428
    Wow, where you live your favorite tool must be a 6" brass and a 6" steel wire wheel an a bench grinder...
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by onformula1 View Post
    Bench grinder for sure, it's a.must have down here.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Jun 2003
    englishtown NJ
    2,676
    isn't the 86/87 200x bolt smaller and a smaller diameter. I have several 86/87 200x bolts, 2 350x bolts(same as 86/87 200x) and a bunch of 85-89 250r bolts. I seam to remember the 250r bolts are a larger diameter, I think because I tried to use one in a 250r and it wasn't a tight fit. I then bought a 250r bolt and it was a tight fit.
    Mar 2007
    Texas
    5,045
    Did this get solved?
    ________________
