Originally Posted by
yamasaki760
....then one of the valve adjusters backed itself out and I took it out, fixed the valve adjuster (checked the valves and saw no signs of piston making any contact at all with valves at any point), and put it all back together.
I'm guessing I did some kind of damage to the head when the valve adjuster backed out that I just can't see (nothing obvious/visible)?
when I first read your original posting the my first red flag thought was the cam shaft had been damaged due to lack of oil and you made the lash adjuster adjustment correcting for wear damage. Which valve adjuster came loose? You stated the adjuster was fixed, does that mean you removed the screw, cleaned/dressed/filed the mushroom end and reinstalled? Next you say you checked the valves to piston for contact none seen, does that mean you removed the Head assembly or did you just look thru the spark plug hole?
You mention it has kick starter compression and as the motor is out and setting on your work bench now you can't check it. An official leak down is the next option or the "poor man's " carb cleaner check as mentioned above. Hell even just using compressed air applied thru the spark plug hole and listening to escaping air in the intake/exhaust ports could work.
Finally or maybe first and easiest could be to check timing for piston TDC in relationship to the generator rotor TDC marking located by the wooddrift key. With the spark plug removed stick a small round rod (maybe a straw/coffee stir stick) to the piston and rotate the crankshaft back-in-forth to find piston TDC. Now inspect to verify generator TDC marking. If its off then the cam and pulse rotor timing are out of sink to TDC as the key has sheared.
"HJ"
’84 YT60
’89 TRX250R (stock )
’90 LT500 Quadzilla
