1980's Yamaha Fork Interchange ??
Does anyone know if the forks swap between the 80's Yamaha Tri Motos and the shaft drive trikes ?
Thank you
Yes they do almost all the parts interchange. I have a yamahauler that I get parts for a trimoto 200 all the time. I also have raptor 660 hubs on my axle for different size rims and tires.
great thanks, my 200 has bent forks ..but had found the other parts bikes
i was given a set of dirtbike forks that happened to have the same size forks as the yamaha forks i got out of the junkyard. sadly i only have one fork boot... have no idea what the forks are to get another....
In having same problem. I have different forks and can't find out what they are to get a rebuild kit
Also I'm sure the axle hole will be an issue
Yes they are 30mm. And yes I have adapters on the one side to fit my axle shaft.
//ArrowChat Integreation Code
