Results 1 to 8 of 8
Thread: 1980's Yamaha Fork Interchange ??
    Aug 2015
    Pennsylvania
    8
    Does anyone know if the forks swap between the 80's Yamaha Tri Motos and the shaft drive trikes ?
    Thank you
    Yamawheeler's Avatar
    Yamawheeler is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2014
    Regina, SK, Canada
    225
    Yes they do almost all the parts interchange. I have a yamahauler that I get parts for a trimoto 200 all the time. I also have raptor 660 hubs on my axle for different size rims and tires.
    Aug 2015
    Pennsylvania
    8
    great thanks, my 200 has bent forks ..but had found the other parts bikes
    kaymo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2013
    Hickory NC
    191
    i was given a set of dirtbike forks that happened to have the same size forks as the yamaha forks i got out of the junkyard. sadly i only have one fork boot... have no idea what the forks are to get another....
    Nov 2014
    Regina, SK, Canada
    225
    In having same problem. I have different forks and can't find out what they are to get a rebuild kit
    Aug 2015
    Pennsylvania
    8
    they are 30 MM correct ?
    Aug 2015
    Pennsylvania
    8
    Also I'm sure the axle hole will be an issue
    Nov 2014
    Regina, SK, Canada
    225
    Yes they are 30mm. And yes I have adapters on the one side to fit my axle shaft.
