Results 1 to 15 of 20
Thread: 200x sprocket gear change
    Jul 2013
    mo
    327
    I want more torque and hill climbing ability out of my 85 200x. Im havin a hell of a time finding a bigger tooth rear sprocket for it. Is the an adapter or different hub for the axle to run different bolt pattern sprockets. I did find a 41 tooth but dont feel like thats a big enough change from 40. Motor is strong and dg piped and k&n filtered. Just always have to enter a hill screamin . And if u let off for a root or rock and get back in the gas she will fall. Thanks guys.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Jan 2013
    minnesota
    5,911
    yes 1 tooth on the rear is not nearly enough . . it needs to be at leadt 3 to make an appreciable/noticeable difference . . i would simply put 1 tooth smaller on the front instead if you can.
    Jan 2013
    minnesota
    5,911
    Jan 2013
    minnesota
    5,911
    this is just one place that has front sprockets.
    http://sprocketspecialists.com/produ...83-85-sku-540/
    also, if you change the front instead of the rear, you will not need a longer chain but you may if you change the rear.
    Jul 2013
    mo
    327
    She has a 12t on front now. Can u get a smaller on the front? I thought that was as small as they come
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by effort=results View Post
    well i have never done that on this model, however, there are at least 4 different sprocket mfgs that make an 11 tooth for the 200x so my "guess" would be that it will fit . . just rotate the wheels once it is installed then look at the engine behind the sprocket to see if paint is scraped off where the chain might rub . . some chains will barely touch the case and make a small wear mark but this is not a prob, but if it is dragging heavily on the case, then dont use it.
    Mar 2007
    Texas
    5,045
    eBay you can find a 40, 41,42 tooth rear just glancing. Fronts 11,12,13,14,15,16,17
    Have fun.
    ________________
    https://www.mikesatvfix.com
    Jul 2013
    mo
    327
    Quote Originally Posted by oscarmayer View Post
    Have fun.
    Ive looked all over ebay. I only found 41 tooth for rear for an 85 200x. I just dont wana go down on another hill . Like this video shows.
    https://youtu.be/XkqNGQ4Rjt0
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Jan 2013
    minnesota
    5,911
    why do you want to spend 4 times the money changing the rear sprocket instead of the front?
    Aug 2007
    Montana
    857
    I ran a 50T on my '83 and loved the hell out of it !!!! Perfect !!!! I found them on ebay bought 2 !! way to cool!!!!!!!
    DO the Best With What you got !
    My Feed back :cool
    Aug 2007
    Montana
    857
    My Feed back :cool
    Jul 2013
    mo
    327
    Thank u so much i just dont know what else would fit. If i typed in 200x theres wasnt much offered. I have a 12 on front . Can a smaller sprocket fit?
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Surprise, AZ
    2,428
    That EBAY one is for a XR200 dirt bike and will not fit.
    These guys have ever size sprocket you want-
    Stock is 12/40
    They have 11,12,13 and 14 counter shaft sprockets and rear sprockets from 28 to 74
    http://sprocketspecialists.com/sproc...talog-honda-c/
    Here's a gear ratio chart-
    http://sprocketspecialists.com/gear-ratio-chart/
    Aug 2007
    Montana
    857
    Quote Originally Posted by onformula1 View Post
    Stock is 12/40
    That 50T fit mine !!!! Click image for larger version.
    My Feed back :cool
    Aug 2007
    Montana
    857
    better shotClick image for larger version.
    My Feed back :cool
