Results 1 to 8 of 8
Thread: 85 200x swing arm bearing size
    Aug 2013
    i have an 85 200x im putting new swing arm bearings in and i up one of the bearings so im wondering if anyone has the measurements for these needle bearings so i can buy one by itself?
    Slidell, LA
    4,738
    Don't know the size but here is 1 on eBay.
    http://m.ebay.com/itm/Honda-ATC-TRX-...034?nav=SEARCH
    You are money ahead to get rid of the old style bearing and upgrade to delrin. I have been running them in both my 200x and 250r and they hold up great. Best part is you don't ruin these when pressing them in. Below is a link to BKM's delrin bushings.
    http://www.3wheelerworld.com/showthr...ngarm-Bushings
    Aug 2013
    oh damn i wish i would have known bout these before i got my kit already have one of my bearings in but if i cant find one of these needle bearings locally monday might just order the delrin...
    are they just one piece that you slide into the swing arm?
    Aug 2013
    just ordered a cheapo china needle bearing on amazon with prime will try to get that in and if i that up or whenever they burn out i will go to the bushings, thank you for your help
    Slidell, LA
    4,738
    No problem. Yes they are one piece. You get rid of the sleeves, bearings, etc. these only need a little grease and a light tap with a rubber mallet and they pop right in.
    Surprise, AZ
    2,428
    Quote Originally Posted by MisterRoboto View Post
    I am not trying to tell you what to do, but unless you need practice removing your swingarm and playing around with bearings, especially the Chinese stuff, send them back and buy bkm's set-up.
    I don't know your ability or style of riding, but unless you only ride your trike down to the mailbox once a day your bearings will be shot before the months over.
    Surprise, AZ
    2,428
    Some how I think we shop at a lot of the same stores!
    Aug 2014
    South Louisiana
    1,915
    Go with the delrin bushings, you will not only be supporting a member who makes them but you will also be supporting 3ww and don't forget about the good ol' US of A.
    Be a patriot, buy delrin....
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
