Page 6 of 8 FirstFirst ... 4 5 6 7 8 LastLast
Results 76 to 90 of 113
Thread: Built from scratch: 250R
  1. #76
    Aug 2015
    Germany, Bavaria
    98
    Wow, great project and custom at every corner and detail, awesome work!!
    Love the pipe work also, been down that road myself, they are a pain in the ass to build but once its done and you look at it, its a damn good feeling!
    Thank you very much, how did you calculate the cones? Did you draw them with cone layout?
  2. #77
    Aug 2015
    Germany, Bavaria
    98
    Some axles after chemical nickel coating,
    The Chainwheel was painted red like every detail on the trike:
  3. #78
    Aug 2015
    Germany, Bavaria
    98
    A small walkaround the trike with mounted axle and wheels:
ID:	221377Click image for larger version.
ID:	221378Click image for larger version.
ID:	221379Click image for larger version.
ID:	221380Click image for larger version.
  4. #79
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Quote Originally Posted by sticker_sääp View Post
    Yes. I used the 2 Stroke Pipe Wizard program (About $25 dollars) and cone layout. What took me FOREVER to understand was how to create each individual section in cone layout. Essentially, all it is, is figuring out the width (or length, as traveling down the pipe) of the section you want on average, and then dividing that into the length of the specific coned area you are dividing. Then you increase the inlet and outlet diameters of each one of those sections, that much. Its VERY easy once you understand the process, but I banged my head against the wall for weeks trying to speak to mathematicians and all sorts of people to figure out how to equally divide the cone chapes, and what the inlet and outlet diameters for each one of those sections would wind up being so I could plug the parameters into cone layout.
    When I did mine, I actually created templates for each individual section of the pipe, versus making the entire thing straight and then band sawing pie cuts out of it which seems to be the more popular methodology. I had 54 pieces laser cut for me by German buddy Hagen, and then I hand rolled and tig welded everything together, each bend and section individually.
Name:	20141001_065250 (Large).jpg
  5. #80
    Aug 2015
    Germany, Bavaria
    98
    Thanks for sharing. You used a lot more sections then me. For my next pipe i will also built at least 40 sections. I think i used a complete new method by designing that thing in CAD. It is basicaly the "saw a straight pipe" method but it was entirely done on the pc. It was also quite puzzeling till i found a solution to devide the angles between every segment. Now this is done within an houre when the "3D scan" of the route through the trike is finished.
    Did you polish the welded lines on the insied? On the pic it looks like you just welded it together. When i did that i had a lot of weld spatters on the inside...
  6. #81
    Live Oak, FL
    15,069
    Mine were all fairly clean on the inside. I did have a few a little rough but overall I was happy with it. As you mentioned, for me also, the challenge was dividing the angles for each section and knowing with exactness what their dimensions were. On the smaller diameter areas I didn't do more than a 5 degree angle on each end. On the larger pieces I went up to 15 I think, in the middle.
    I really like your cad method - it is a little beyond my realm of expertise but I can definitely appreciate the modeling process and work it took to put that together in that way. Here is one more picture of mine finished as well as a link to my build thread and then you can have your thread back from me
    http://www.3wheelerworld.com/showthr...ighlight=rotax
    Sent from my SM-N910V using Tapatalk
  7. #82
    Aug 2015
    Germany, Bavaria
    98
    Great built from you, that trike looks awesome.
    Dont worry about the threat, i realy like to corespond with someone who is gone that way too...
    What steel and plate thicknes did you use?
  8. #83
    Live Oak, FL
    15,069
    I had two sets of everything made. One in mild steel, 1mm thick that I built this pipe out of. And then another set out of stainless steel that had been annealed for easier forming/shaping.
    I have not done anything with the stainless sets yet.
Name:	20140811_074559_HDR (Large).jpg
  9. #84
    Aug 2015
    San Diego
    12
    That's some patience you have there.
  10. #85
    Aug 2015
    Germany, Bavaria
    98
    Sorry for the delay of my upgrades... I am quit buisy with the building of my flat at the moment...
    A pic from the zinc plated steel parts:
    (They are not only for my trike)
  11. #86
    Aug 2015
    Germany, Bavaria
    98
    The Carb and cooling hose was mounted:
ID:	221738Click image for larger version.
  12. #87
    Aug 2015
    Germany, Bavaria
    98
    The guards (I dont know how you guys call them!?) for my radiators were built from anodized aluminum sheets and aluminum pipes.
    They hold the shrouds an protect the radiator from dirt:
ID:	221740Click image for larger version.
ID:	221741Click image for larger version.
    after welding and cleaning:
ID:	221743Click image for larger version.
ID:	221744Click image for larger version.
    finished:
ID:	221746Click image for larger version.
ID:	221747Click image for larger version.
  13. #88
    Aug 2015
    Germany, Bavaria
    98
    Quote Originally Posted by jamve View Post
    Yes the whole built used to take about one year and three months...
  14. #89
    Aug 2015
    Germany, Bavaria
    98
    Sorry for letting you wait, i had to built an stainless exhaust for my 200es, attached is a pic as excuse
ID:	222404Click image for larger version.
    A steel kickstarter was milled for the trike but then i found out that it will not clean my pipe and i had to think about a better concept for the kicker...
ID:	222403Click image for larger version.
    (thats the part of the tricke that i am not realy proud of...)
    Here is my solution, it is a bent steelrod wich was welded to the cut lower pice of the milled kicker...
ID:	222408Click image for larger version.
ID:	222409Click image for larger version.
ID:	222410Click image for larger version.
  15. #90
    Aug 2015
    Germany, Bavaria
    98
    First test of the engine...
    https://goo.gl/photos/mYbbLjio5VQbDfJv7
    And the first test ride...
    https://goo.gl/photos/Ri1hUd2oikothCiv6
    And here you can se a beautiful pic of my technical drawing skills:
