Results 1 to 12 of 12
Thread: Help with 250sx rear rim fitment
    Sulphur Springs,Texas
    1,005
    I am wanting to get some polished wheels for my 85 250sx but need some guidance on the rear rim selection. My main concern is clearing the rear brake drum. I have found some rims but not sure if they will work with offset and size.
    here is the link. https://www.rockymountainatvmc.com/p...=%201087590012
    I used and 85 big red since it is a 9' rim and that is what I am going for. thanks guys.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Sep 2014
    Michigan
    86
    Cool
    Hello, I wish I could answer you question directly but I don't know much about the drum brakes and what will fit. I did however see this 250sx for sale with new aluminum wheels. Maybe the seller can answer your questions if you contact them? Good luck, I think it looks good and would be the way I would go if I had a 250sx.
    http://flint.craigslist.org/snw/5172700124.html
ID:	220883Click image for larger version.
ID:	220884Click image for larger version.
    1985 ATC 350X all original/OEM Honda parts
    1972 US90 Dickson Designs 2" stretched tube chassis, 200x Forks, Piranha 150cc, VM26
    1985 ATC70 Piranha 114cc BBK, Ported Race Head, TB300 Cam, Spangler's Exhaust
    1985 ATC70 Piranha 150cc, VM26, Z40 cam, Ported head, Two Brothers Exhaust, 2" stretch
    1970 Honda CT70125cc Mikuni 24, XR80 Forks, Aluminum Swingarm, Carbon Exhaust
    1972 Honda CT70110cc e-start, Mikuni 20 carb, Carbon Exhaust, Aluminum Wheels
    1993 Honda Z50R all original
    1,005
    Thanks SSLS1, I reached out to the seller to see if he could provide any information.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Jan 2011
    Choctaw, OK
    2,755
    What you need to know about the 85 SX rims is this. The hub on the right is part of the brake drum. The rims needed for the 85 are a deep bell on the back side so the rim clears the brake drum. By deep bell I mean the rim is straight on the inside unlike other rims that are stepped. If you put a stepped bell rim on an 85, the rim hits on the brake drum. In 86, Honda stood the wheel hub off of the brake drum a couple of inches moving the rim away from the brake drum eliminating the interference issue. The solution is to go with an 85 straight bell rim or move up to a 9" rim then you could use a stepped bell rim.
    1,005
    thanks for the info Flyingw, I felt that going to a 9" would be alright with no issues but wasn't for sure.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    1,005
    The seller got back on those pictures SSLS1 and said he is running 10" in front and back.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Sep 2014
    Michigan
    86
    Great to hear he was helpful, I would be buying that 250sx if I had not just bought a mint 350x just 1 day befor it was listed. Looks cool with those wheels IMO.
    Check out this 86, looks like he installed some OEM 200x aluminum wheels. .......
    http://flint.craigslist.org/snw/5163120325.html
ID:	220973Click image for larger version.
    Nov 2010
    Oshawa, On, Canada
    2,123
    I have a whole pile of 9" rims that will not fit the 85 250sx. You need to make sure they are not stepped bell rims. The only 9" aluminum rims I have that fit my 85 are ITP 9" 3+6. I cannot remember the exact model.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    2,591
    What about wheel spacers? Would they work? Good idea or bad? I'm thinking about doing the same to my sx and I already have the extra 8" rims.
    Nov 2010
    Oshawa, On, Canada
    2,123
    With 1.5" wheel spacers ( ONLY USE THE BOLT ON TYPE! ) Almost every rim will fit an 85 sx.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    1,005
    Some nice trikes popping up for sale up North SSLS1!. I'm not as a big fan as everyone else seems to be with the front Bear Claw tire. Yeah those definitely look like 200x rear wheels on that 86'. Those don't look too bad but not really what I'm looking for on my setup. I want to try to keep things matching. That 85' is pretty spot on the what I was looking into. The seller gave me the exact info I'm needed. Funny how the word "rare" is loosely used nowadays.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Jan 2014
    La
    1,062
    Dude for the wheels if your looking for a stock look use the itp steel wheels. As for tires it's really depends on what kind of riding you do. For a good all purpose tire I would go with some dura knobies all the way around. If you need something a little more aggressive I would put bear claws on the back and a dura knobbie on the front.
