Hey, so I've posted on here a couple of times already about the issue and I still cannot seem to figure it out. I've had the carb apart countless times and the top end has been apart twice already. The cam chain and tensioners have all been replaced and the clutches have been also replaced, so everything has been apart except the inner case. The carb has a new float needle as recommended by Muthey. For some reason the carb still leaks also. The carb has been completely taken apart, cleaned and looked at. I can't find anything wrong with the carb but I have attached pictures of it to see if something catches your eye. It has a new air filter and the exhaust has been blown out with a pressure washer (whether that was a good thing or not). I replaced the CDI with one I got off of eBay. The whole bottom end is off of my parts machine which was a 84 ytm 200e. So my end result right now is a electric start 200e with a auto decompression regular 200 top end. I have attached a video of it running. Any help will be greatly appreciated.
