Thread: Tri Moto Rear Suspesion
    Aug 2015
    Edwardsville, Illinois
    24
    So I have seen a lot of talk on here about the pro-tech suspensions that different people have bought and installed for their Tri Motos. I was wondering where people got these, or if I needed to make a custom bracket and just buy a hydraulic shock? I would appreciate any information people have about their suspension kits!
    Apr 2014
    Edmond, KS
    2,591
    You can't just make a bracket and mount a shock to have rear suspension. A solid rear end has no up and down movement. all of the parts would have to be changed in order to put suspension on it. That's why people used to sell whole frames to convert your trike.
    Aug 2015
    24
    So is there a company that makes a different swing arm and mounting bracket for it? I have seen people who have the conversion done to their trikes and I was wondering if anyone knew somewhere I could get all the stuff I will need to make the conversion?
    Yamawheeler's Avatar
    Yamawheeler is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2014
    Regina, SK, Canada
    225
    Any type of conversion like that is usually a custom fabrication job. I am currently working on hydraulic rear brakes. It's been a headache and I still haven't mounted it yet that's also due to not getting to the shop to work on it though.
    Nov 2014
    Regina, SK, Canada
    225
    Best bet get all the rear axle parts for ytm 225. Drive shaft needs to be changed out so each end had U joints. The diff can be the same and rear axle. Tires can stay just need to switch out driveshaft and linkages then cut out the mount for the rear axle and weld in a structural bar for shock. Have to have a swing arm mount as well so there's more fab work there. It's more work than buying a wrecked 225 frame and switch parts over.
