Results 1 to 9 of 9
Thread: Honda ATC185s flywheel removal. Need help
    Jun 2015
    Oklahoma
    732
    So I need to remove the flywheel on my 185s, and the threads that you usually screw the puller into are destroyed. How to I go about removing it now? Maybe using a puller hooked on to the recoil start basket? Also the impact sockets dont fit in the hole to remove the flywheel nut, so what is the best way to remove it using a ratchet or johnson bar?
    Thanks
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Jan 2014
    La
    1,062
    the only thing I can think is a clutch basket remover tool that might take it right off. If you do get it off please replace the flywheel.
    Scootertrash's Avatar
    In the sticks
    4,638
    You don't necessarily need an impact socket to remove that nut.
    With the right size and type of puller you may be able to pull it using two of the bolt holes for the pull start basket. Just be careful not to thread the bolts in too deep and mess up your ignition/lighting coils.
    Jun 2015
    Oklahoma
    732
    Ok, thanks. I know a guy that has some old parts engines for sale and I think there is a good flywheel on it, so I may try and snag that. Would it work to use a slide on a puller that was held on by those 2 bolts? I might be able to make something up then that would work with a slide . But would that break anything or cause any other problems?
    Da velder
    Feedback:
    Slidell, LA
    4,738
    Funny I was going to mention a slide . Think that will work just fine.
    Hampton, Virginia, C.S.A.
    2,664
    we used a regular flat puller with 2 bolts threaded in to the recoil basket holes. we put a regular socket on the impact to get the flywheel nut off. this was all on a 200s my uncle just picked up
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Mar 2007
    Texas
    5,045
    Get the flywheel removal tool from eBay. Shipped about $12. Do it right the first time and keeps from damaging bearings or cases and what not.
    ________________
    https://www.mikesatvfix.com
    Jun 2015
    Oklahoma
    732
    [QUOTE=oscarmayer;1382758]Get the flywheel removal tool from eBay. Shipped about $12. Do it right the first time and keeps from damaging bearings or cases and what not.
    I would get the tool but since the flywheel threads are destroyed it would not do me too much good.
    I will use a flat puller then, and a regular socket.
    Thanks
    Da velder
    Feedback:
    Mar 2007
    Texas
    5,045
    Ahh ok missed that. Then a good gear puller is in order and put a bolt on the crank end and endure the head is ground down or use a Allen bolt
    ________________
