Results 1 to 3 of 3
Thread: Winter Maintenance
    Sep 2015
    Worcester, MA
    34
    Question Winter Maintenance
    Hi guys I am just wondering what I should do for winter storage and just general maintenance? I want to prevent tank rust, etc...
    Thanks
    BigRedGrizzly's Avatar
    BigRedGrizzly is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Jersey
    296
    Here's my routine. Top off the fuel tank. I use a mix with the fuel to deal with the ethanol. Can't remember the name off hand. Then I add fuel stabilizer. Run it for about 5 minutes and turn the fuel off at the tank. Let the engine die and drain any excess fuel from the bowl using the drain screw. I also use a battery tender for my electric starts. If you don't have tender take the battery out and store in the house or a heated room. Cold kills batteries. I will go out and start the machines as the warmer weather begins to approach. Mostly because I miss the sound and smell. This year though, I plan to be riding in the snow.
    May 2015
    San Diego, CA
    1,796
    I live in San Diego.......what's a winter?
    Grizzly is correct with the stabile and keep gas in the tank.....it prevents rust.
