Results 1 to 8 of 8
Thread: mugen cylinder ?
    poohbee1's Avatar
    poohbee1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    terre haute indiana
    404
    mugen cylinder ?
    I do not consider myself a motor guy but the iron sleeve in that cylinder looks huge. http://www.ebay.com/itm/Rare-Mugen-2...0a93c9&vxp=mtr Is it sound not having the nikasil
    Jun 2003
    englishtown NJ
    2,676
    its got a "310" sleeve in it. Really a 293 on first bore and 308 on last bore. You will find alot of trx/atc's have big bore sleeves and/or stroker cranks, uneducated buyer dont even know what they have. It used to be a common thing when last bore on stock sleeve was worn, to rebuild it with a ~72mm sleeve, well, before aftermarket cylinders were cheap and easily gotten. You can build a 330 that externally looks like a stock 250, depending on crank/rod and piston, it may not even have a spacer plate under the cylinder.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    that's a steal so far,,,
    phantomtracer's Avatar
    phantomtracer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    392
    Is that someone from this board?
    Looks great.
    Surprise, AZ
    2,428
    That is the holly grail of 250r cylinders, they are a work of art and very rare! Killer port design too.
    What's more rare than this? I guess a factory HRC bulge port would be, but you only see them in a few old magazines. I think they were truly crushed or sent back to Japan
    Jun 2003
    englishtown NJ
    2,676
    when duncan worked with pro-x to design the first aftermarket cylinders, they used a factory hrc cylinder(would love to know how they got one- 68mm nickel-sil and radical proting, but looked very close to a factory cylinder from the outside), mugen cylinder from a 85-86 atc250r and mugen for a 85 cr250r. All the best from the 3 were put together, along with o-ring head and a type of cool-head. That being said.......mugen cylinder is very cool to have and rare.....your run of the mill pro-x, saber, sphynx or esr cylinder has a better port layout and makes more power. But for its time, nothing could touch a mugen except for factory hrc stuff.
    Oct 2006
    2,504
    Sold for $1325.
    San Marcos Ca.
    712
    What a deal !!!!!!!!!!!!!!!!!!!!!!!!
    * 1970 US90 Red
    * 1985 ATC 200s
