Thread: 85 250sx Tranny question
    Legns is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2014
    Catskills NY
    156
    Ok so I picked up a new toy 85 250sx for 200. I new it needed some work the guy I got it from blew the rear end no biggie, I have a couple of those laying around. It runs great no smoke to speak of and great compression. So I change out the rear and get ready for a test ride. Now reverse works and supper low works fine. 1st sounds like a garbage disposal and it will barley move. 2nd is like neutral I got nothing. 3rd and up are fine. So my first question is do I have to tear the top end down to get to the transmission or can i leave it be and and still replace whatever is wrong?
    Apr 2014
    Edmond, KS
    2,591
    I think you do have to pull the top end off first.
    Mar 2003
    Australia
    1,919
    100% full tear down unfortunately.
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Aug 2014
    Catskills NY
    156
    Thanks So as it is my first time tearing down a lower end any tips/suggestions I should know about.
    If 1st is bad, it's the thrust washer missing because some BOZO, took out the countershaft by the 3 allen bolts on the left.
    You'll find it in the bottom of the motor. Very common problem, 1st doesn't engage fully....
    I have fixed this by pulling the kickstarter gear and retrieving that thrust washer; Look at the parts fiche!!
    Aug 2014
    Catskills NY
    156
    Thanks ill try that
