Big Red 200E rear rack mounting issues please help
Hey guys. I took my rear cargo rack off my Big Red 200E to paint it and now im struggling putting it back on. The 2 holes where the rack mounts to the frame itself (the holes directly above where the "arm thing" mounts to the rack) were busted off, somebody re-welded one but the other is gone. I figured I could drill a hole below the busted off part, then just mount the arm and the rack to the frame with 1 longer bolt, essentially doubling up and turning 2 holes into 1. The arm still mounts in about the same spot as before. However, for some reason the rack is not centered at all on the trike now, the left side (where the hole is busted) is right above the fenders, but on the right, which should be the good side, its like 2-3 times higher, and not level at all. the holes in the plastics where they mount to the arm things on the underside don't line up, and I have no idea why. its extremely frustrating. It was on there before and now it wont go on the way it was. Please help, I know my description was sorta confusing, any questions just ask. All help is appreciated.
3 Wheelers:
1983 Honda ATC 200E Big Red "The Barn Find"
1984 Honda 200x with 200s engine "Auto-X"
1981 185s junker SOLD
1983 Honda ATC 185s "the original" SOLD
1984 Honda ATC 200s "The FrankenTrike" SOLD
1984 Honda ATC 200s "ole reliable" SOLD
1986 Honda ATC 200x SOLD
