Results 1 to 2 of 2
Thread: 200es cam chain replacement help needed
    Sep 2009
    Rural Retreat
    3
    Hi,
    Im in the process of rebuilding my 200ES and I was wondering how or what tool I need to pull the
    thing in front of the can chain where the stator assembly is??
    The cam chain guide is worn also. Need to rep[lace that to.
    Thanks
    Nathan Lovern ,Va
    nathan.lovern@yahoo.com
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    You need a flywheel puller, don't use a gear puller, spend the $9 on ebay to get the right puller, it is a bolt within a bolt, very easy to use. I have seen many stator/flywheels destroyed with gear pullers or trying to pry it off.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
