Results 1 to 7 of 7
Thread: Left Outer Dust Seal Replacement Question -84 200es
    Cold Lake, Alberta, Canada
    3,019
    I looked at the schematics and read the manual. Still not sure of my solution. It appears that I can remove the seal without the axle coming out. Does anyone know if it's possible to remove the left outer dust seal on the final drive without removing the axle first? My situation is that the drum is rusted onto my axle badly so removing it may not be an option without inflicting major carnage. The manual shows a bit of a shoulder on the axle; that worries me. Is the shoulder on the iside of the seal, or does the seal ride on it? If I had a spare drum I wouldn't be worried LOL, grinderrrrrrrrrrrr! Thanks in advance for any options/solutions.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Oct 2008
    NB, Canada
    852
    I think the seal rides on that shoulder, and the shoulder is was goes up against the ring gear. I rebuilt one last summer, but I'm not 100% sure how it goes.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    3,019
    Ok I got my answer. I removed the seal easily without removing anything. Now to deal with my stuck hub:-(
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Oct 2008
    NB, Canada
    852
    break out the blue tip wrench haha
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    3,019
    I let it soak overnight with the trike on it's side. I hit the backside of the hub a little with a 4lb sldege once or twice and I can see light around the axle now. I'll let it sit a day or two more and go at it again. BTW the seal is discontinued so I got one off eBay. Ouch!
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Oct 2008
    NB, Canada
    852
    All-Balls makes a diff bearing and seal kit that comes with that seal, but it's about $100. I think they make just the diff seal kit as well tho.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    3,019
    I think I paid around $30 for NOS which isn't too outrageous. Seen that kit also. That was plan B.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
