Thread: yamaha 350 warrior wont move .
    fingerlakesny
    2,834
    Sitting on JACK STANDS . Start it up , put into gear , let out clutch and nothing....put into reverse and axle starts to go backwards and then nothing.... clutches or transmission ? no noises...
    250r dust runner
    6,810
    Sounds like the clutch . Does it shift threw the gears ?
    Something else to check is the tranny output shaft .
    fingerlakesny
    2,834
    appears to shift through all the gears . does the reverse rod that's broken have a sweet spot it needs to be in so everything mesh's correctly ?
    250r dust runner
    fingerlakesny
    2,834
    Welp , Started it up (still on stands) and now it will turn forwards till u give it some gas , then quits....hopefully clutches....anything to look for when tearing it down ?
    250r dust runner
