Results 16 to 30 of 37
Thread: New member restoring a 3 for dad. Lots of questions.
    San Marcos Ca.
    715
    Are you still in need of a pull starter . I have several of them . PM me if you are interested .
    * 1970 US90 Red
    * 1985 ATC 200s
    Sep 2015
    IL
    35
    I picked one up last week. Thank you though. I did find out that the bolt that hold on the little cdi flywheel was missing, so I'm probably going to have to set the timing on the bike again. I also discovered a stray green wire that I cannot find on the wiring diagram. It's in the same sleeve as the black/yellow wire for the coil.
    Sep 2015
    IL
    35
    So it never dawned upon me that this bike is a cdi, therefore there should be a cdi box somewhere. Looks like the wiring harness has been hacked up so much that it has been completely eliminated. Any good sources for a wiring harness?
    Sulphur Springs,Texas
    1,005
    those fenders turned out really good after you dipped them. pretty impressive! Are you looking for a new or used wiring harness?
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Sep 2015
    IL
    35
    A working harness. Condition doesn't really matter
    Sep 2015
    IL
    35
    Well awesome news everyone. Turns out in don't have a 185, I have a 200. Not the news I was looking for. Don't know what I'm going to do with this thing now
    Aug 2015
    Idaho
    855
    I have a spare '83 200s that is mostly complete. If you want something off it let me know. I'm fairly new to this site, so not sure how to sell parts.
    1,005
    Yeah that stinks it's a 200. What brought you to that determination?
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Cold Lake, Alberta, Canada
    3,019
    Quote Originally Posted by What2007 View Post
    Keep working at it, learn from it and flip it for a profit. Then find a complete running 185 that needs a little TLC. These "cheap" machines are wolves in sheeps clothing sometimes.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Sep 2015
    IL
    35
    Quote Originally Posted by Jd110 View Post
    I really need a wiring harness to get spark.
    Sep 2015
    IL
    35
    Does anyone know where I can get a cheap CDI unit? Bought a harness and trying to get spark.
    Jan 2014
    La
    1,062
    Well actually your bike is a hodgepodge of alot of different bikes. The front end is off a 200m or 83 200. your rear fenders are 185s . your rear tires look like there off of a 83 200 200m And your tank is off of a 200s. So you really need to run the vin number off of the neck of the frame to be certain what it originally was.
    Sep 2015
    IL
    35
    Quote Originally Posted by 86125m View Post
    Frame vin keeps coming up invalid in the decoder. From what I can tell, it says JM3TB0505DC257551
    Sep 2015
    IL
    35
    Still having issues getting spark with the new coil, plug, and harness. How often do these stators go out? I'll try to test it, what would its normal output be?
  15. #30
    Apr 2012
    USA
    4,129
    I was just about to chime in that I make wire harnesses new, but sounds like you already have one.
    Any more details on the plastic dip process? Is it the same thing as recoloring plastic (hot water in a tub with colored die)?
    Based on the manual decode methods for that VIN....
    Year: 1983
    Yea that is all I know how to do manually lol.
    Based on this site though... http://atcvin.webs.com/
    1983 ATC200
    Sorry I had to be the one to confirm the "bad" news. In my view point, the 200 should be an upgrade over the 185 if it runs well. I'd say if you have your heart set on a OEM 185, buy another "parts" bike, and combine the best of the two to make one. As confirmed by another member, it has the 185 rear fenders, which is another part that seems to be hard to find around my area. If the seat pan is good I'd keep the bike just because of the value of those two parts until you get the 185 you plan to build you won't know what parts you will need. I know a lot of parts interchange between the 200 and 185.
    Now onto your spark issue. The service manual troubleshooting steps mention the following items in this order:
    Faulty/Fouled Spark Plug
    Faulty CDI unit
    Broken or shorted high tension wire
    Faulty AC generator
    Broken or shorted ignition coil
    faulty pulser generator (part under the cdi cover)
    wiring
    pulser generator rotor air gap incorrect
    Kind of odd it lists a spec adjustable thing last lol.
    Coil specs:
    Pulser Generator - 20-60ohms and gap of 0.3-0.4mm
    Ignition coil - primary 0.2-0.8ohms, secondary 8-15k ohms
    ac generator (stator) - lighting coil white/yellow to ground shows connection, exciter coil 245ohms (black/red wire I'm pretty sure)
    Odd the exciter coil didn't have a range of spec, but the service manual is a more generalized one for the 185 and 200. Of course it never hurts to mention... is the kill switch to on? =)
    For the giggles of it, I looked up the 200x specs, which might have a bit higher ohm specs than the 185/200 but should be similar and gives an idea on how much of a range is acceptable.
    Pulse Generator: 30-200 ohms for 83, and 50-150ohms for after 83 and the gap is the same
    Exciter coil 100-400ohms
    ignition coil: primary is 0.2-0.8 and secondary is 3k-5k ohms
    Good luck. There are service manuals around, but I don't have the link saved in a handy spot .
