Results 1 to 15 of 17
Thread: 1984 ATC 200M....Just purchased
    Sep 2015
    Western most part of N.C.
    53
    I picked this ride up for $125 yesterday. The guy said the chain came off with him one day and he parked it and hadn't fooled with it since. Said it has been sitting six or seven years. The tank has some pinholes rusted in it in the lower section nearest seat. I have not torn into it yet but it needs a few small things like a brake lever, probably a new chain, some paint in a few places to freshen up things and obviously I'll put new brake shoes on it. All in all it looks to be in my opinion in pretty good shape. No doubt it was worth the money I spent and the best part is when I shot a little gas into the cylinder it fired right up. I will be needing some help on this as I go along starting with some wiring. If you look in the second picture there is a green wire that's obviously a ground wire and he said it wouldn't crank unless that was plugged in and that the neutral light stays on all the time. So any suggestions as to what I need to do to correct this? Are there any wiring diagrams on this site? Thanks in advance to any and all help
ID:	222230   Click image for larger version.
    Sep 2015
    53
    Sorry for the sideways pic I don't know why it posted that way. Maybe one of the mods can fix it?
    Jan 2014
    La
    1,062
    Looks like a pretty good bike. I know I love my 200m.
    Tionesta, PA
    5,747
    Do a simple google search of "ATC200M wiring" and you will find the schematic. All green wires, as shown in your picture are ground on any Honda trike. Just trace out where the wires come from and go to - it's pretty simple. Pull the tank off of the bike for a bird's eye view of all the wiring.
    Cold Lake, Alberta, Canada
    3,019
    Welcome. Lots of info on coating tanks. Fairly straightforward if you adhere to the instructions to a tee. Sounds like your Neutral swith is stuck in the grounded position.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Sep 2015
    53
    The wire that I have my finger on coming from behind the sprocket cover was a green wire that was pulled apart and I hooked it and the green wire that was grounded to the CDI cover in the 1st pics together as I thought that's prob where it went???
    Sep 2015
    53
    Help...Am I right in my last post?
    Sep 2015
    53
    All the wiring diagrams I have saw are confusing as in it will have a wire labeled G/R but it doesn't have G/R in the chart to right of the page. Any help?? In the following pic u see a green wire coming from the sprocket area,,,,when I hooked that green wire that was grounded to the cdi cover to that wire the neutral light stopped working??
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    [QUOTE=dwil4;1385185]All the wiring diagrams I have saw are confusing as in it will have a wire labeled G/R but it doesn't have G/R in the chart to right of the page. Any help?? In the following pic u see a green wire coming from the sprocket area,,,,when I hooked that green wire that was grounded to the cdi cover to that wire the neutral light stopped working??[/
    That green wire is for the neutral indicator. On my 200m the switch is broken so the neutral light is always on. Is your bike in neutral? If it is in gear then maybe that is why the light seems to not work. Nice bike by the way.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Sep 2015
    53
    Yes it was. I'll try again but I am confused by the diagrams I have saw. You can see there is a G/R coming from the neutral switch and the starter button but there is no G/R in the color code chart. There also is no Y/B in the chart. I can't assume it's green and red because that wire is not green and red
    Sep 2015
    53
    bump...............
    Sep 2015
    53
    Any comments on that wiring diagram?
    Jun 2015
    Oklahoma
    732
    Quote Originally Posted by dwil4 View Post
    Yeah, I am not sure why that would be. Do you just want to get your neutral indicator switch working? As was said in an earlier post I would check your ground.
    Da velder
    Feedback:
    Sep 2015
    53
    Yea I would just like to get everything back to normal working order. If I hook it to the wire coming from behind the sprocket it does nothing. If I hook it back to the wire that the previous owner had grounded to the CDI cover then it stays on. lol
    Sep 2015
    53
    How would I check to see if my neutral switch is bad? It is on at all times
