Results 1 to 15 of 24
Thread: Hondaline Speedo Drives Mythbusted
    Mar 2003
    Australia
    1,919
    So today I got my NOS speedo drive from atc500x. Thanks for that Dom. Anyway I took the thing apart to grease it all up and had my 250es one apart also next to it. Now it's common misconception for people to think that these drive gears are geared differently to make up for the 22inch vs 25inch tyre size, either
    in the pinion gear or the ring gear. This is a myth. Both speedo drive units share the exact same ring gear and pinion gear. Therefore making all the parts interchangable. The ES one is stamped HA0 and the 250sx HA6.
    It is beyond me why Honda sold them as seperate items. Why not just have one part number for the lot of them. It would be great if someone had the means or want to take apart a 350x or 250r one and compare that to the ES and SX one. I know the outer housings are a different shape but I would bet the internals share the same ring and pinion also, maybe just in a backwards setup.
    Anyhow, just thought this might be of interest to someone.
    I have used the sx speedo drive gear on my 350x speedo setup and I bet it will read fairly accurate.
    Cheers.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Austin, Massachusetts
    1,591
    where is the difference made up? in the speedo itself?
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Apr 2002
    s.w. michigan
    6,498
    Nah, the speedo heads and trip meter heads are definitely all the same (several different mounting brackets for different trikes). Tire sizing could be the only difference judging by Matts observations.
    And adding into the confusion not all the speedo drive units are marked with any stampings.
    Perhaps it really is only the axle sizing hole and direction of rotation ???
    May 2009
    S.E. Michigan
    1,251
    For the record, what is the tooth count on the output gear (the one connected to the speedo cable)? Also, are the gears a worm drive configuration (I'm assuming), or a conventional ring and pinion like an automotive axle?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Apr 2002
    s.w. michigan
    6,498
    Exploded veiw
    Yes, worm gears.
    Mar 2003
    Australia
    1,919
    Didn't count the teeth to be honest. Just meshed the gears together and did a visual. What I'm saying is I think they all do the same thing and John is right in saying it might just be the axle size and the way they spin. They must have a 10% tolerance or something in accuracy. They are a pinion and ring gear I guess but not 100%.
    1,591
    is the front axle diameter on the ES the same as the SX? I can't imagine that the identical drive goes on a 22 inch tire and a 25 inch tire. the difference has got to be made up somewhere. If the axle is greater diameter in the ES then I suppose as long as the ratio is maintained in the housing and drive body of the speedo than the internals could remain consistent. ?? its interesting.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Mar 2003
    Australia
    1,919
    Axle diameter is the same. Right through ES,SX,350x,250r. Axle size has nothing to do with it at all. Very interesting. Maybe just a gimmick for Honda really. Who cares what speed your doing, as long at the needle moves right!
    Marty is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    Mesa, Az
    644
    I have noticed that the sport atc speedo drives 200x, 250r and 350x,mounted turn different than others to activate speedo needle.
    1,591
    so the odometer is also dogsh!t?
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Nov 2007
    Mesa, Az
    644
    Odometer is not dogs t! What it means is drives for ATC 200x, 250r, and 350x mount on opposite side of 200s, big red drives!
    1,591
    right. i understand that. my point is that these things are either wildly inaccurate (which i can't believe) or that there is a mechanical explanation for the difference in tire size from machine to machine. it can't be accurate and the same. So, how is it different?
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Mexico
    9,018
    Quote Originally Posted by redsox View Post
    Based on my cable drive speedo street bike experiences I would disagree with you accuracy's doubts. 10% is nothing when you consider how the diameter of an ATV tire varies with speed and these weren't even destined for street riding, so its doubtful they ever had to pass any sort of DOT test.
    1,591
    it surprises me very much that honda would not QC that. at least make an attempt. one less tooth on the drive gear or something. AND they have different part numbers? but they're identical? am i the only one that thinks thats weird? i agree that with the relativly low travel speed of these machines, its close to moot, but the mileage is a significant difference over time.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    Mexico
    9,018
    Sounds crazy, I know, but consider the cost to Honda to R&D that extra tooth on the drive for a vehicle with tires that can grow 6 inches at speed. It was a crap shoot to calibrate them from the get go. I don't read a lot of street bike reviews as of late but back in the 80's when I was immersed in such things I recall the magazines reporting large discrepancies in speedo VS actual readings during the tests. It's just not something the manufactures seemed to care about.
    As far as the 2 part #'s thing I can't say as it relates to Honda. It's the one brand that will never take up space in my shop, so I have no personal experiencing parts searching for them, but I've seen Yamaha & Ducati (Cagiva) make a duplicate part and change the part number, or discontinue an old part and keep selling it for a newer model even though it still fits the old vehicle.
