Thread: Honda 110 help/ input
    sandusky, Ohio
    127
    Im rebulding the top end of my 79' honda atc110. I took the head to my machine shop and he said the piston and bore look good hes just going to clean it up and hone it for some new rings. Im lookingon ebay for some standard bore rings but most of them listed say there for 1981-85 models. Were the 79' rings different? The only rings i saw listed on ebay for a 79' were fifty dollars wich seems expensive. Anywhere else to get standard rings for a 79' ?
    I also want, no...need a new exhaust. There are a couple dg exhausts on ebay one has a kinda straight pipe and i think this would mount like the original Exhaust up through the frame and out the back but the other listed seems to have a u-shaped header pipe and im not sure what thats all about. Also open to any suggestions on the exhaust brand and where to get it.
    I just want to do this right without putting 500.00 into a 500.00 machine so i want a good exhaust but realistically my kids and i will probally put ten hours a year on this bike so i dont need some expensive exhaust. The dg's seem to be around 130.00 shipped.
    6,808
    Yes the rings are a different thickness , if it were me just order a piston kit for the 81-85 model and install that in your 79 .
    May 2013
    Brownsville, Tn.
    1,271
    About the only aftermarket NEW exhaust you can find is the DG that is similar to the old PK pipe. If you keep and eye on ebay ususally you see some USED aftermarket pipes come through for a little less money.
    A good used Super Trapp just sold for $75.99
    http://www.ebay.com/itm/HONDA-ATC-90...vip=true&rt=nc
    * Nicholson 500 Race Bike *
    sandusky, Ohio
    127
    If you have a second will you look at ebay. If you type in "honda atc110 exhaust" the first one listed is a dg pipe. Is this the one i want that will mount just like the stock one?
    May 2013
    Brownsville, Tn.
    1,271
    I do not know of any aftermarket exhaust that mounts like the stock exhaust (running through the frame). They all swing out to the right side....
    Jul 2014
    KS
    104
    Beatrice cycle should have the rings. Just watch eBay for a good used OEM exhaust. Or troll your local classifieds for a parts machine.
