Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Tire sizing??
    Jul 2015
    IA
    18
    If they make a Kenda Front Max in your preferred size that's what I'd go with. Excellent grip for turning in dirt and grass.
    Sep 2015
    Western most part of N.C.
    53
    Thank You. Ill check it out
    TwiZ's Avatar
    TwiZ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2015
    Elk county Pa.
    187
    Ive always liked the carlisle knobby on these ole bonecrushers..and they seem to resist gettin flats better than a stock style tire
    1984 Honda 200X
    1984 Honda 200S Bonecrusher
    1975 Jeep CJ5
    Sep 2015
    53
    I can not find the Kenda max in a 25x12x9. I like it but no luck.. Any more suggestions?
    Jun 2014
    madison
    102
    carlisle stryker 25x12-9 is the way to go
    ATCT is offline Just Too Addicted Arm chair racerJust too addicted
    Dec 2005
    Phoenix, AZ
    709
    Quote Originally Posted by wamulass View Post
    I could see using those on the rear, but for a front? Why not get the same front tire that you bought for the rear? A 200M had the same tires for all 3 from the factory. And those do look good. I might consider getting some for my '84 250R, seeing as I can't get the Ohtsus anymore (damn).
    And in response to your initial question regarding the size, take a look at the 200S. They came with 22x11-8 tires. The M had the bigger tires because I think it was supposed to be a less expensive version of a Big Red (i.e. you could add a back rack, as you have, for hauling, etc.)
    1984 Honda ATC250R
    Jun 2014
    madison
    102
    I prefer not to go the 2-ply route as they puncture easily. Had half a dozen plugs in my kenda front max before it was beyond repair. Stryker tires run large, are very tough and wear like steel.
