Page 12 of 30 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Results 166 to 180 of 440
Thread: ATCr125x
  1. #166
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by sweetip2000 View Post
    If you have a propane torch you can fire up that frame about a foot at a time and the paint will fall off like dandruff with a wire brush right down to the bare metal. No grinding or sanding. btw the epoxy paint from valspar is impervious to gasoline and oil and you can brush it on but be careful it runs....... .... awesome job and keep up the great work.....
    Thanks, I blasted the frame to remove the paint. I will be using krylon cover max, banner red for the frame.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  2. #167
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by oscarmayer View Post
    I think they have a external res if I re all which is why we chose the yami
    I was just wandering because I saw this and it looks like it will fit
    http://www.ebay.com/ulk/itm/121777626184
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  3. #168
    Surprise, AZ
    2,428
    Quote Originally Posted by Jmoozy27 View Post
    It looks like it, but that is Chinese.
    I would rather have a used Nissin, but that's how I roll.
  4. #169
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by onformula1 View Post
    Yeah, I figured for the price that it was worth a shot. But to think of it the way mine will be mounted probably wouldn't work well being that the mounts make the MC lean. I need the res to be as flat a possible.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  5. #170
    Surprise, AZ
    2,428
    Keep in mind, your set-up will work fine if you think the reservoir is the problem- it is a sealed system and the res gets over filled with brake fluid to the point when you put the rubber diaphragm/cap on fluid should leak out all over the place, that way if the bike/trike is leaned to the side or upside down the brake does not get contaminated with air.
    The reservoir can be mounted to the bars if you install a long enough hose.
  6. #171
    Surprise, AZ
    2,428
    I forgot, Oscar Mayer is just trying to slow you down because you are smoking him on this build...HAHAHA!
    Choppy, Choppy! Mike, take off the skirt.
  7. #172
    Jan 2014
    La
    1,062
    Hey Jmosy I used a similar rear master cylendar on my 84 200x however I had to make an adapter plate for it to mount. It works great just was heck to bleed.
  8. #173
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by 86125m View Post
    Yeah, those Chinese masters work but they are a mother in law to bleed. When you get a minute do you think that you could measure the distance center to center of the mounting holes?
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  9. #174
    Willamstown PA
    5,820
    I told people years ago what master to bolt up with no issues. 04+ YFZ450 egg the holes and bolt up. BAM!!!!!!!!
    Screw that Chinese crap...its cheap for a reason.
    12 pages are the frames not done yet c'mon man! I'm working on 4 machines and building a bike lol.
  10. #175
    Aug 2014
    South Louisiana
    1,915
    Physically working on them, or having them worked on??? I'm just making sure that everything is done right the first time brother. I'm a family man first and a trike enthusiast right after that.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  11. #176
    Willamstown PA
    5,820
    I come home, work on hour 1 hour eat then go in garage. I'm working on 4 at time right now. It's burning me out. I'm butting up my rear end and suspension right now.
  12. #177
    Mar 2007
    Texas
    5,045
    yep! I did not realize they went to tankless! sweet!!
    ________________
    https://www.mikesatvfix.com
  13. #178
    Aug 2014
    South Louisiana
    1,915
    That's good, mine are similar but these 70 hour work weeks have been putting me back a bit. Haven't had a weekend off in 2 months. I'm not complaining though.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  14. #179
    Willamstown PA
    5,820
    GET MONEY!!!!!!!!!!!!!!!!!! buy veal parm subs!!!!!!!!!!!!!!!!!!!!!!
  15. #180
    Jan 2014
    La
    1,062
    Hey Jmosy Here is the link to the exact master CYLINDER I used. It has the measurements listed in the pics. http://www.ebay.com/sch/aply20/m.htm...1&_ipg=&_from=
