Thread: Plastic kit for YTM200EL/how to restore plastics that have been left outside
    Sep 2015
    Western Sydney, Australia
    23
    Anyone know where can i get a whole set of plastic for my 1984 YTM200EL?
    If there is no one out there making it....How can i restore sun faded plastic.
    plastics have been left outside for about 6-8 years...washed with pressure washer and the faded layer came off but it feels really really rough..
    Thanks.
    Jacky
    Aug 2015
    Idaho
    838
    It's ALOT of work, but this is how I did mine.Scrape faded plastic with a sharp razor blade held at a 45 degree(make sure to scrape backwards and don't cut into plastic. Then start sanding with 220 grit wet. Then 320,400,600,1500 and last 2000 grit. Each grit takes a lot of sanding. Last: there is a product called plastic renew. It goes on last. This worked great for me. Hope it helps you.
    Jul 2012
    Penfield NY
    660
    I have not tried this yet, but it seems good. A visual always helps.
    https://www.youtube.com/watch?v=yWPwCXLSIdA
    "See, morbid and creepifying, I got no problem with, long as she does it quiet-like. "
    Trikes:
    1982 Honda ATC250R(in process), 1984 Honda ATC110, 1984 Honda 200s, 1985 Kawasaki KLT160(not running...yet)
    Quads:
    1990 Suzuki LT250S, 2013 Suzuki LT-Z400, 2014 Honda TRX450R SE
    Sep 2015
    Pennsylvania
    17
    So what i am doing right now is that i took a razor blade and scraped all the older oxidized plastic off then sanded with 220 grit on a orbital sander. I am using a spray paint called krylon fusion to paint my plastics. It is formulated to bond to plastic without any other prep. I will post pics after i am done but the difference is night and day if u do it in layers and lightly sand between layers. Hope this helps.
    Aug 2015
    Idaho
    838
    Let us all know how that paint looks next year. And don't be shy around that paint job,either
    Dec 2013
    I used the boiled lin seed oil and paint stripper method on my atc 125m. It worked marvelously. click here
