Results 1 to 15 of 22
Thread: Paint
    Jan 2015
    Rock Valley Iowa
    35
    Paint
    Guys, Would any of you know how to repaint back fenders. Like do I use normal paint or not. I feel like it was flake when it bends? What should I use to repaint it.
    Jan 2013
    minnesota
    5,911
    well if you really want to paint them, one option is to use solvent base, catalyzed paint with flex additive and put some adhesion promoter on them first.
    any scratch you can see will show up
    Sep 2015
    Pennsylvania
    17
    I am painting mine right now. I am using krylon fusion formulated to bond to plastic. Spray in layers and slightly sand between layers. Difference is night and day! Dries in 15 minutes which is nice. What color do you want to paint?
    Jan 2015
    Rock Valley Iowa
    35
    I would like to paint it read. I painted it once with plasti- dip, but gas eats it away so it looks bad.
    Apr 2014
    Edmond, KS
    2,591
    So how are you going to get gas on your rear fenders? You sound like you might be fun to ride with! Just busting your chops.
    Jan 2015
    Rock Valley Iowa
    35
    No, Well I painted the tank to and that is coming off, but the fender paint is coming off to from my boots so i want to paint it all again.
    Aug 2015
    Idaho
    842
    PAINT! On the fenders? Really? That's the equivalent to painting tires. If you want your work to last, ask a professional near your home. Or watch some YouTube on plastic restoration.
    Jan 2015
    Rock Valley Iowa
    35
    Quote Originally Posted by Jd110 View Post
    Yes paint! I had to repair them with plastic welding because they were cracked. So plastic restoration wont fix that part. And that is why i asked because I don't want to put paint on if it will just chip and flake off.
    Jul 2014
    KS
    104
    Sometimes paint is the only practical option, when things are so bad they can't be polished. Sounds like that is your situation. I've used regular Krylon and Rustolem with surprisingly good results. Be sure to sand well first and clean with acetone well to remove any silicone that may be present. Wet-sand between coats and be sure to let it cure thoroughly. It will still take a lot of flex and not crack. If you are flexing more than that, appearance is probably not your top priority anyway--know what I mean?
    Jun 2009
    Leander TX
    2,217
    Anybody else used Krylon Fusion on fenders? I'm curious about durability vs other paints.
    Fenders flex so much...
    Jan 2015
    Rock Valley Iowa
    35
    Quote Originally Posted by Devilsclaw View Post
    Yes I do. I just wasnt sure how well paint would hold up on fenders. So it should work fine your saying?
    Jul 2014
    KS
    104
    If it's done right it will take s lot more flex than you would think. I was amazed. Thing is, once you paint it--if it does end up cracking, you can just sand it and paint it again in a few years. They really shouldn't flex that much in riding anyway, unless abused. Usually kids climbing on them is the biggest problem.
    Sep 2015
    IL
    35
    I just plasti dipped mine over the weekend. It's rubberized so it'll flex all day. You just have to watch out for rubbing through it. Click image for larger version.
    Aug 2015
    Idaho
    842
    i bought my 200 big red from a 76 year old, who owned a motorcycle shop for 40+ years. He painted the fenders right before I came to look at it, to hide the faded, brittle plastic. I would bet it didn't take him much more than a couple hours. That night I took everything apart. Scraped paint & brittle layer off fenders. Then began to sand and sand and sand for somewhere around 100 hours. Now I know that's an unthinkable amount of work to some, others get it & do what it takes to do it right. My fenders look new from a foot away and will last another 30 years.
    Jan 2015
    Rock Valley Iowa
    35
    Quote Originally Posted by What2007 View Post
    Yeah I did that to. I did the take to because it was beat up and I fixed it and I didn't know gas eats away at it, and the fenders are starting to peal already with just leg rubbing. Thats why I am redoing it. It did Look good at first. Here is what they Looked like.
ID:	222756Click image for larger version.
