Thread: Atc 200e knocking..... video posted
    Nov 2008
    ontario
    1,055
    http://m.youtube.com/watch?v=Rhu_Cosp8EQ
    Is this a rod knock or? Any one ever heard something like this?
    proud owner of a trx300ex quad and an 85 atc 70
    Nov 2008
    ontario
    1,055
    Ive since removed the top end and the clutch cover. The wrist pin looks like it was heated up at one point and has metal smearing on it/ wear the inside of the rod small end has some scoring too... think i can get away with a new wrist pin? Also when i move the crank side to side (entire crank) theres loads of play because the crank bearing moves side to side in the case. I thought these were a press fit? Big end of the rod feels perfect btw
    6,807
    Not press fit to the cases just to the crankshaft itself . I would be more concerned with up and down play .
    Nov 2008
    ontario
    1,055
    In definitly going to rebuild this over the winter as a project the factory exhaust is almost perfect no rust. The seat pan is rust free, still has the factory tool kit and came with the ownership!
    Oct 2008
    NB, Canada
    852
    I have fixed the wrist pin ends of a rod before with a brake cylinder hone, but that was on a couple different bikes that had just 1 big burr on the inside of the rod in the center, and a new wrist pin wouldn't fit. Hard to tell in the video, but it sounds like the timing chain and guides are wore as well and making noise.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    TTown, Alabama, United States
    845
    I'd get a good wrist pin and see how much wobble it has. I bought a new wrist pin for my rebuild and decided to polish the rod out with some fine sandpaper, and was happy with the results and the fit. it was lightly scratched. But if your wrist pin is rainbowed and galled up there's a good chance that nothing will be in spec.
    Sounds like a good excuse to build a hot motor to me
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
