Ok, I would run the SCAT-TRAK 7 paddle EDGE tires then . . Around 10.5 lbs which is one of the lightest tires by far that is available and all the traction you will need without bogging the engine too much . . The paddles are 7.8" tall x 13" long with a slight scoop shape.
Here's the order form from Rocky Mountain which has one of the lowest prices on them . . Click on review button and scroll half way down the page and check out the reviews.
https://www.rockymountainatvmc.com/p...-Edge-ATV-Tire
SPARE STUFF
I would also bring a 12 tooth counter shaft sprocket and master link and an inner tube and possibly a radiator cap with the next higher rating to help insure your fluid won't bubble out . . Rocky Mountain has the rad caps also.
SWINGARM ADJUSTMENT
If you have enough chain adjustment to move the rear axle back at least 1/2", I would do that too.
