Tri-z Timing Marks
I was having my top end redone on my Z and decided to replace the crank seals as a precaution while I waiting for cylinder work to be done.
Question. After I replaced the seal on the stator side, I noticed there are 3 marks at the top of the stator and 3 on the flywheel that are supposed to line up with the line on the case. Can I put these back on and tightened them down without the top end being on and make it right? Or basically, how can I be sure I have the stator on in the right postion? And since the flywheel has a key, I don't think I can get that one wrong.
Want to be sure it is timed right or at-least on the marks right.
Is there a thread on this subject?
Thanks
Just-Tri-It
:Trikes Owned:
1985 Tri-z's 3
1986 Tri-z
1984 YTM 200ERN 1
