Thread: 1982 Honda 110 atc won't start
    Mar 2015
    Central Iowa
    54
    I have a 1982 honda 110 that is getting spark, fuel, and has compression. Pulled it with a truck and backfired a little bit but wouldn't pop off and start. I've never encountered anything like this before so responses would be greatly appreciated. Thanks!
    1985 Honda 250es Big Red (Daily Driver)
    Multiple Honda ATC 90s and 110s
    1984 Honda 200s
    1983 Honda 185s
    Cold Lake, Alberta, Canada
    3,019
    If it's got all you say it does, it sounds like you may have jumped a timing chain or partially sheared a woodruff key. Just make darn sure it has GOOD spark and GOOD compression and it's not flooded out first. And make sure your exhaust isn't plugged up.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Mar 2015
    Central Iowa
    54
    Thanks coolpool. Will definitely check timing chain now and keep you updated when I get time.
    1984 Honda 200s
    1983 Honda 185s
    Apr 2014
    Edmond, KS
    2,591
    How's the spark plug? Also, is it getting gas to the engine? If there's something clogged in the carb, you could get gas there, but none through it. Just a couple of thoughts.
