Results 1 to 15 of 15
Thread: ATC200E Randomly stops sparking, Need HELP!!!
    Nov 2013
    NB canada
    67
    Ok so here's the story, I have a ATC200E thats been running perfect for the last 4 years that Ive owned it. Randomly wouldn't start, check for spark, no spark. So after trying for a few hours to figure this out, randomly I have spark, start up go for a couple rides. Following week, no more spark, again start trying to figure it out, hour later I have spark and starter up and again go for a couple rides. Then today get ready for a ride, no spark and can't get it figured out. All wires look to be in good condition and well pluged.
    Also my wiring harness is strip down to the very minimum, no volt regulator, no fuses, no solenoid, no battery. I had done this from the start.
    So really I only have the stator, CDI box and coil in my harness.
    Anyone have any idea what my problem could be? This is getting very annoying!!
    Thanks in advance!
    Jul 2013
    USA
    737
    Intermentent electrical....fun, have you tried pecking on cdi when no spark? Followed by trying a cdi thump when no spark? So it runs good above and below half throttle, maybe bypass the killswitch when it does it.
    Nov 2013
    NB canada
    67
    What do you mean by pecking and thump? Never heard those terms before lol
    Jul 2013
    USA
    737
    When it's not getting spark tap on the cdi with a handle and see if you get spark after you tap on it. Does it ever fail while running, shut off?
    Cold Lake, Alberta, Canada
    3,019
    I've heard of the drop test on cdi's. Kind of a last ditch attempt to get them working. Intermittent spark would point to a cdi issue I'm thinking.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Nov 2013
    NB canada
    67
    The first time it happened, it was idling, cold start and about 30 seconds after it died and the second time was right after I unloaded it from my truck. Ill try giving it a few taps! Thanks for the advice.
    Jul 2015
    SW Oregon United States
    145
    Nov 2013
    NB canada
    67
    Little update, got it running, all I did was give the CDI box a few good tapes and its runing, who knows for how long lol
    Nov 2013
    NB canada
    67
    And thanks for the link mendoau. Good info.
    Mar 2007
    Texas
    5,045
    I bet it's the sparkplug wire and boot. had this just happen on my son's ATC 70. $25 for a whole new coil with wire. coil sucked but whire and boot were good. so reused stock coil and runs like a top!!!
    ________________
    https://www.mikesatvfix.com
    Jul 2015
    145
    It;s not a plug wire or coil. It's what has been stated...a cdi unit.
    Jul 2015
    145
    Quote Originally Posted by A-Martin View Post
    martin... unless you want to rely on that thumping technique just step up and get a new cdi. search out the myth buster thread.
    Nov 2013
    NB canada
    67
    Yeah I want to, but for me its 20$ + 26$ shipping then in canadien dollar that 57$ I think Im going to try to find a used one locally.
    Also little update, Every next day that I ride it I have to tape the CDI then shes good to go for the day. Weird. lol
    Mar 2007
    Texas
    5,045
    ahhh oh so we know for sure it is the CDI then. sounds like a wire broke inside.
    ________________
    Oct 2008
    NB, Canada
    852
    200E should be the square plug CDI anyway I think, so no need to rewire.
    I see you're in NB, I've got square plug CDI in Fredericton if you're still looking.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
