Results 1 to 8 of 8
Thread: wiring a TRX 70 CDI to a Chinese engine
    Connecticut
    1,605
    Picked up a TRX 70 project with a Chinese engine. Not running and wiring is somewhat butchered.
    My question is the honda CDI has a light green/red stripe wire that goes to a neutral safety switch.
    What should I connect this wire to on the five wire china engine? Appreciate any advice!
    Tomcall's Avatar
    Tomcall is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2010
    Arizona
    215
    Go to hondaatc70.com and link for tech help there is an article about this
    Jan 2014
    Massachusetts USA
    782
    I think that wire should probably stay open. It probably activates a rev limiter, the same way my TRX250 and other Hondas rev-limit in reverse. Get it running with that wire insulated, then try grounding it. Then you'll know for sure what it does.
    1985 Tri-Z 250
    1985 ATC250R
    Jan 2011
    Choctaw, OK
    2,755
    Electric start? Lights? I have wiring diagrams for the different configurations.
    Connecticut
    1,605
    It is electric start only no recoil or kicker.
    Engine has five wires coming out of motor a yellow, white, green, black with red stripe, blue with white stripe
    Jan 2011
    Choctaw, OK
    2,755
    Here ya go.
    Jan 2011
    Choctaw, OK
    2,755
    Now, for a neutral safety circuit, there should be a bundle of wires back by the sprocket. Find the wire that shows ground continuity when the shifter is in neutral. Route that wire to the ground side of the starter solenoid. That will enable the solenoid only when the tranny is in neural.
    Mar 2007
    Texas
    5,045
    you can also go to www.tboltusa.com and talk to Vince he can help you with a harness that would work.
    ________________
    https://www.mikesatvfix.com
