I'm replacing my handbar switches with a new one, and in the wire diagram (attached below) has an optional connection point (Brown + White/Yellow). Is there ANYTHING out there that actually uses those connections, hondaline accessories etc? I'm thinking about omitting it to save a little cost etc.
I have all the other wiring figured out, and slowly working on putting it together. This is kind of a "test fit" for a handlebar switch I came across that has the correct switching properties to match our older machines.
Some of the guts actually interchange with the 350x headlight switch guts. Of what I can see, the only thing that does not fit is the lights on/off switch, it is the correct size, fits in the housing nice, but the back side is too thick and won't assemble sadly. My 350x is going to have a starter button "extra", half thinking about wiring it up to a horn. If all goes well, I'll probably wire one up for a 200es big red (and any other machines that uses the same layout) and offer them up on ebay/3ww shop.
I also added a photo of the new switches (right) vs old (left). Same width, same layout on switches, extra starter button, and the back plate has a locator pin that has to be removed in my application.
Btw, for the people out there that has tried this before, yes.. the kill switch is wired correctly, no backwards kill switch issues here.
If anyone wants me to do this for their machine, I should be able to make it work for just about anything, just remember it does not have the choke slider like the 250es/sx, but I'm working on that design too. Price won't be too bad, have not figured it out yet, but will be somewhere around the price for the chinese reproduction ones on ebay, except these are actual Honda parts adapted to work on older machines.
