Results 1 to 3 of 3
Thread: 110 pistons
    May 2014
    Mendon Illinois
    38
    110 pistons
    Hey guys! I have been told that a Yama TTR 125 Piston will work in a 110. It has a 54mm stock piston size, the compression of the wiseco piston is 11:1, and wrist pin is 15mm, Effort=results knows a guy that has done it and I am going to talk to the guy about it and see if it required any other modifications other than to be bored. Ill keep updates posted! Might be a little bit easier to do it than to track down and buy NOS pistons.
    85 Honda 350x
    85 Honda 350x
    85 Honda 350x
    86 Honda 350x
    86 Honda 200x
    85 Honda 200x Hybrid (350x Suspension)
    84 Honda 200s
    78 Honda 110
    RIDE RED!
    Mar 2007
    Texas
    5,045
    your better off measuring your piston.
    (diameter, piston pin to top of piston edge and piston pin diameter.
    go to www.tboltusa.com and order a piston. you can even get a higher compression piston for more performance and a cam. Talk to Vince tell him the "Crazy Texan guy" sent ya.
    ________________
    https://www.mikesatvfix.com
    Michigan UP
    1,005
    Maybe you should start another thread on it, seems 4 isn't enough
