Results 1 to 11 of 11
Thread: 84 200es not starting
    Aug 2015
    Swisher, IA
    92
    I bought a 1984 Honda 200es a few weeks ago thinking that I could get it running. It is in very good shape so I did not hesitate to pay $250 for it even though it wasn't running. It has good compression and spark. I also cleaned the carb completely and made sure it was not clogged up. When I pull the pull cord I don't seem to hear any noises in the engine that could be causing a problem. I want to have an idea of what it could be before I pull the engine out of it. I don't have too much spare time so if there is anything else you guys think would fix it without taking the engine apart please let me know. Thanks
    "You see, in this world there's two kinds of people, my friend. Those with loaded guns and those who dig. You dig."
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    1983 Yamaha Tri-Moto 200
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    What's the compression at ? Should be around 140 ( mines at 120 , runs good but can be hard to start ) Good spark ? Maybe . change the plug ( again )
    Make sure you're getting fuel to the carb .
    Cold Lake, Alberta, Canada
    3,014
    What chop says and make sure the exhaust isn't plugged by a mouse nest or something.Check the valves clearences if compression is questionable. Does it spark using the electric start and pull start? These things have a habit of developing weird spark characteristics usually caused by the cdi.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Aug 2015
    Swisher, IA
    92
    I will check those things. I know that I am getting fuel to the engine and the exhaust does not seem to be clogged. I get spark when I pull start it and I have tried spraying carb cleaner directly into the cylinder and trying to fire it over.
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    3,014
    Actually carb cleaner seems to stall an engine out. Can you spray a little gas in it? You should be able to hear the suction from the intake with the air filter removed and feel puffs of exhaust when you pull it over. I have to ask, you're using fresh premium gas?
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Aug 2015
    Swisher, IA
    92
    Yes Im using fresh 91 octane gas, no rust in the gas tank.
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    Aug 2015
    Swisher, IA
    92
    Also the exhaust is not clogged, and I was getting readings around 140 for compression.
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    Apr 2012
    USA
    4,133
    Hmm if it has compression, spark and fuel, the only thing that makes sense to me is ignition timing.... maybe it is 180 degrees off or something? I'd check the mechanical timing and the rotor under the "CDI" cover.
    How does the plug look? Is is super dry, or does it smell like gas, wet?
    Carb clean, and a ton of other cleaners depend on the brand rather an engine can run on them or not, either (starting fluid) works much better just for testing, and if your brave enough, LP/Map gas can make an engine this size idle, just make sure not to light it.
    Aug 2015
    Swisher, IA
    92
    I think you may be right about the valve timing. That seems like the only other thing it could be. Ill try that out and see if I can get it going. I havent done valve work on these big reds before, are they pretty simple to adjust?
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    Apr 2012
    USA
    4,133
    For the valve (mechanical timing), generally there is a mark on the fly wheel that lines up with a mark on the side cover, and the cam gear/sprocket has a mark that lines up with another mark on head. Generally mechanical timing would cause low compression if it is off. It never hurts to make sure it is lined up though, a service manual is best to reference on the process.
    What I was talking about is the ignition timing (spark time), the cdi and pulse generator control that and the pulse generator has a range it can be adjusted. I don't remember if there are any sort of markings for the default starting spot or not. Another thing that is in the same area is the advancer for the pulse generator, it has springs that can break and it would throw the ignition timing way off.
    CDI cover should be 2 simple screws to take off, and is just a dust cover for the components.
    Here is an image of it. The rotor part has a pin that makes it line up with the cam, if it was damaged, or removed (if removable don't remember), then it could be put on at the wrong angle and be sparking when it does the engine no good.
    Mar 2007
    Texas
    5,045
    check to make sure the crank is at T on the flywheel then make sure the line aligns up, if the entire rotor is facing down, your 180* out. take rotor apart and reassemble..
    ________________
    https://www.mikesatvfix.com
